[C2] What is the secret to headlight switch?
Is it a triangle stem? I don't recall, but it seems that it has to be rotated the right way to catch, but it has been many many MANY years since I messed with it.
IIRC you have to take the switch out of the dash reinsert the **** and shaft it should catch. Pull the **** ALL the way out before pressing the release button. Then press the button and smoothly slide out the shaft. Leave the switch like that and reinstall it in the dash. Once in shove the **** and shaft in firmly and it should catch.
I'll try it again tomorrow. If I recall, in the past it would do this and then, mysteriously suddenly catch. Worst case scenario, I'll just buy a new one...
Switch
Had same problem. Kept pulling it out and rotate a bit and push in.
Took about 5 minutes messing with it and it did engage.
Using excess force is not needed.
Fred
Fred
FWIW, the switch slider (inside the switch housing) needs to be in the headlights "on" position, all the way out, for the spring loaded release button on the bottom of the housing to work. The release button won't engage the latch on the switch slider in any other slider position.
It is difficult, almost impossible, to reinstall the **** in the slider without being able to use the release button to open the latch. If you've accidentally pushed the slider in, you may or may not be able to reinstall the ****.
