crossfire engine
Old 02-23-2017, 06:08 AM
redcorvette84
1st Gear
redcorvette84's Avatar
Default crossfire engine
I want to replace my crossfire motor with an LS1 i don't mind the crossfire but here in Australia it's a pain to get parts locally. Unlike the LS1 which has no dramas what i would like to know is what problems i may face before i start.
Old 02-23-2017, 03:31 PM
Patsgarage
Patsgarage's Avatar
Received 1,596 Likes on 1,074 Posts
Just Google "C4 LSx swap" and you will find more info than you can ever use.
Old 02-23-2017, 03:34 PM
73n95
73n95's Avatar
If they can stuff it into a Miata (they can) you will get into your 84. Have fun with it. That should be a killer swap.
Old 02-24-2017, 07:01 AM
OzyC4
OzyC4's Avatar
I reckon your biggest problem will be getting it engineered. Every modification will have to be assessed and it will cost plenty. I think your best plan is to consult an engineer first and find out what exactly is involved and what it will cost.
I've just had my 88 examined to make sure it complied with the ADRs that were used in that year for the VASS certificate required by Vicroads. It passed all tests except that I had to fit amber rear indicators. He had the car for half a day and charged me 800 bucks.
Old 02-24-2017, 08:30 AM
ghoastrider1
ghoastrider1's Avatar
did you tell him... " have a go you mug"
Old 02-25-2017, 07:08 PM
OzyC4
OzyC4's Avatar
No but I was definitely thinking "this bloke must be related to Ned Kelly!"
Old 02-25-2017, 07:34 PM
midlifecrisis1979
midlifecrisis1979's Avatar
will be a bad **** if u do it, researched it a bit before I decided to stroke my l98. people make motor mounts and everything her in the states for this app. I'm thinking if you guys have insurance auctions outback on totaled cars like we do here in the states that would be the best way to score a donor for the project. best of luck to you.
Old 02-25-2017, 07:49 PM
Cjunkie
Cjunkie's Avatar
I like that swap!
Old 02-26-2017, 04:53 AM
corvettenorway
corvettenorway's Avatar
https://www.corvetteforum.com/forums...okievette.html
Old 02-26-2017, 05:37 AM
armybyrd
armybyrd's Avatar
In the middle of swapping my '88. Ls1tech has a ton of info in the conversion section. Don't listen to the many forum racers who say the truck accessories won't fit. It's been done and they do. Depending on what route you go it can be pricey.
To crossfire engine
Quick Reply: crossfire engine
