Starter motor?
Starter motor?
Hi
I went out to jump in and drive away the other day and when I turned the key everything seemed fine until I went to crank it - then heard what sounded like a ball peen hammer hitting an anvil (not loud) and the car went dead. Tried it again - car is dead like a totally dead battery.
Charged the battery - again same thing.
Car was running fine the previous day.
Is this just the starter motor shorting the battery out? Or the solenoid or something?
Thank you! Love the C5!
Jim
Jim
When my starter went out the car was completely dead when you tried to crank it. Your situation doesn't sound like a starter, rather a battery with insufficient cranking power.
Edit, here is how mine acted before I replaced the starter. Never had an issue again after it was replaced.
just replaced my starter today... it was doing the same as black 02, not all the time, but after driving (sometimes..) i went ahead and replaced the starter before it started acting up more.
the new starter sounds better and seems to spin the engine over easier..
Not to derail the OP's original thread but I wanted to inject a related question...I really appreciate Black02' video. About a week ago, I got some gas and when I attempted to start the car, there was not a sound. Although they say insanity is repeating the same thing over and over and expecting a different outcome, but in my case, at the gas station, I sat there and continued to try starting the car. After 5 minutes or so, the car started right up... so I believe I do have a starter problem. My question is if anyone knows... can a starter stop working intermittently before it goes out for good?
Thanks for the replies.
This is not a daily driver (especially in winter when it leaks like a sieve), and the date on the battery was 11/11, so I bought a brand new gel Die Hard ($200!).
I was sure this would nail it but - bam! Same exact thing. It took the brand new battery down to 0 volts. I guess that ices it - the armature must be stuck, shorting out the circuit.
Is the starter easy enough to R&R on the driveway? I don't normally wrench on this car but otherwise I would have to have it towed.
What is a good replacement choice for a '99 FRC?
Thanks again for the comments. I appreciate it
Jim
Jim
I've had the same problem in the past intermittently. Found out one of my battery terminal bolts (side post) were corroded even though it looked not bad. Replaced them for a few bucks (any auto store has them) and it starts right up now without issue.
Start checking the easiest stuff first.
Jim Harmon (04-11-2017)
I had no idea about the potential discontinuity at that side terminal connection. Turns out, just as you indicated, I had a corroded positive terminal bolt (corrosion inside the boot out of view) and it was an intermittent contact! $5 fixed it.
Love my old C5 FRC. Love the forum! You guys are the best.
Thanks again beboggled!!
Jim
I just went through this last week.
Replaced battery, then took the starter out and had it bench tested.
The starter failed, so I bought a new one.
After all that work removing it, and installing it, still nothing when I turned the key.
The ignition switch was the culprit.
Replaced it, and car starts up every time..
Check the ignition switch.
How I found out it was the switch was easy.
When I tried to start it, and nothing, I turned the key on and off three or four times, and the engine started.
Shut it off, and nothing.
Once again, turned the key on and off a couple of times, and it started right up.
Bob.
Bob.
Bob.
Bob.
When you hear the pinging of the starter it means one of two items, usually a battery with less than 12.5V can cause the problem of insufficient voltage and the slow tuning of the starter. However it is usually less than 10.5V for this to happen. The more common problem is the solenoid in the starter is worn and needs replacing. While you can remove the exhaust and access the starter as stated above, I would replace the starter with the newer (Truck) starter using two long bolts rather than on long and one short. Two many C5 owners have ended with the dreaded cracked starter boss where the shorter bolt threads in.
