Vacuum Line 84 vet
Old 02-23-2017, 05:07 PM
Mikei16
5th Gear
Mikei16's Avatar
Default Vacuum Line 84 vet
I am looking for the vacuum hose that connects to this valve. I looked up the vacuum diagram on mitchell and I don't see this one?
Thanks for any help
Mike
Old 02-23-2017, 06:08 PM
billschroeder5842
Zen Vet Master Level VII
Support Corvetteforum!
billschroeder5842's Avatar
Received 1,140 Likes on 845 Posts
Not sure on the 84, but on my 82 it connected to the air diverter valve. Should be similar
Old 02-23-2017, 07:33 PM
ex-x-fire
ex-x-fire's Avatar
That should have a foam cover, as this is where the vacuum is released when the throttle is closed. This keeps the egr valve from being open at low/idle speeds. Your picture shows the other 2 vacuum lines & thats all thats in the diagram for the egr solenoid.
Old 02-23-2017, 08:29 PM
Buccaneer
Buccaneer's Avatar
Location: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Received 1,004 Likes on 688 Posts
Old 02-24-2017, 12:34 AM
Hot Rod Roy
Hot Rod Roy's Avatar
Yep, that's all there is. You've got it right.
I see you're fighting the wire bundle on top of your oil filler. I traded sides with my rocker covers to solve that problem. That gets you away from the delicate high pressure safety switch on the back of the a/c compressor, too! Much better!
Old 02-24-2017, 06:12 AM
Mikei16
5th Gear
Mikei16's Avatar
Thanks for your helps
Mike
To Vacuum Line 84 vet
Quick Reply: Vacuum Line 84 vet
