Clutch recommendation, please.
The car is a driver with 3.90 gears and bolt-ons. I don't need anything crazy.
Thanks!
Master cylinder? Remote bleeder?
Thanks!
I have the Mantic ER2, I running about 550 RWHP, feels a little stiffer than stock. Mantic says its good to 650-700 RWHP.
As for master cylinder and remote bleeder I have Tick.
Received 1,261 Likes
mcleod and act are also good brands to look at... I highly suggest shying away from an oem clutch and going with a good aftermarket unit, you won't want to go back and do all the work over again when the pedal still sticks to the floor or you can't shift in high rpms with oem clutches... you might also consider getting a clutch that will hold more power than you have that way if your plans change you will have some room to grow into it
I thought for sure the answer was going to be a C6 Z06 clutch, or something like that. Damn.
So, Tick master and bleeder?
