[Z06] New GM heads for AHP build
In order to minimize downtime and assuring that heads with more miles don't get out on my low mileage car, I have started to plan. I know I will have AHP do the build with Moldstar 90 guides. My question is has anyone shipped them brand new heads from GM? Bad idea? I would sell my existing heads to recoup some of the expense. Does this save any money when you send to AHP?
Zero reason to do that. Mileage on heads doesn't matter at all since they replace all the wear items. It doesn't matter if you have 200k cores or 10k cores. They make them like new.
Landru (02-25-2017)
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
RICH
Eh ........... get the new ones. Then the guides could be measured and see if GM can get two new heads machined within spec
And you could give Rich some business
DH
DH
Supporting Vendor
Received 1,012 Likes
We have core sets in stock and ready to rework to your exact specs!!!
All our heads be it new or used will meet the exact same standards/specs by the time we are finished processing them. In other words it does not matter if you start with a new or used set of heads. If you much have a new set of heads we recommend purchasing from Rich above (RichieRichZ06) and having him drop ship them to us. We have had several sets of new heads drop shipped to us in the past.
hp@americanheritageperformance.com
or
310-326-2399
http://www.americanheritageperformance.com/
or
310-326-2399
Me, I'd take a 100K used pair of stock heads to do over new. The older castings have been heat cycled countless times and if they were going to fail would have done so a long time ago. Resurface, new seats, guides, valves and call it a day.
If you bought new, then you'd know the valves have not been stressed under a potential condition where the guide clearance was very high, or seat concentricity was way off (or both). In either of those situations, valve life could be compromised.
So your saying if those 2 conditions were present on a used set of heads there's no way reworking them could rectify those issues ?
Supporting Vendor
We then do our treatment process on them and that makes even an older valve better than new.
All are core heads and components meet our standards before we start processing them/accept them as cores.
With our core heads you are assured to get better than new components and a better than new final product.
MTPZ06 (03-02-2017)
Its not a bad angle.
When the guides were machined for the valve, they holes were not perfectly round, AND the guide material softer then it should have been.
Valves not polished as well as they could have been.
No, I am not saying that. I am saying the valves may need to be replaced, which would add costs. The stem itself could have stress cracks, in addition to the valve head. It's just a risk to consider.
