l98 minimum machine shop rebuild
Gonna rebuild my l98 1987. Ran 200k miles before giving up the ghost, never blew just started knocking in the bottom end so I shut her down and haven't cranked since 2008. Hoping to rebuild to spec for another 200k miles. Provided that the block isn't damaged what nos parts can I get to do this? I see that the original crank is still available? I would rather replace parts than have them machined if possible which will hopefully only leave the cylinders to be addressed. Would like to purchase a set of heads rather than have mine refurbished, don't care about performance, looking for reliability and longevity like the original. I wanna keep everything as original as possible and prefer ac delco parts. any advise is greatly appreciated, I know there are a lot of great crate motors and mods out there for better performance but I just want my girl to be the way she used to be when we met in 1998.
The heads are going to be your problem. Do a search on here (google is your friend) about the early aluminum heads, they are prone to cracking. If yours are in good shape (no cracks) consider yourself lucky. To my knowledge only used units are available. If it were me I'd try to have the originals redone and run them.
If for some reason you think about going to the newer vortec head be advised your original intake will not match up. Scoggins-Dickey used to sell an intake that would match the TPI to the vortec heads.
I bought a set of vortecs, rebuilt from a machine shop... one ended up being cracked.. check them b4 handing over money..BTW, that shop was selling them newly rebuilt for a hundred bucks a pair.
http://www.superchevy.com/how-to/eng...-tpi-manifold/
http://www.chevyhardcore.com/tech-st...-reader-guide/
MAKE SURE you can find a manifold for sale b4 buying a set of these heads. Edlebrock has stopped making these manifolds. Luckly I bought a manifold first.
Remember, you are going to have to have it bored so means new pistons and rings. New cam bearing,main and rod bearings.complete gasket set, freeze plugs, most likely crank work,rebuilt heads, maybe new injectors, why put on an old water pump, timing set,and on and on. It aint cheap.
If you do just a bottom end rebuild, with 200,000 on it, you'll need to pull the engine again soon. Do you really want to do the job twice?
At 200,000 miles, call that engine toast! The fastest and cheapest way to continue with the fun factor is a crate engine! Lots of choices available, and if you choose correctly, you will again have a reliable, smooth running Corvette! You'll probably be surprised how much better "the old girl" will run with a fresh engine! I'd highly recommend you get an engine that has been ballanced!
don't care about performance, looking for reliability and longevity like the original. I wanna keep everything as original as possible. I just want my girl to be the way she used to be when we met in 1998.
gonna build it cheap as possible back to spec with as little machine work as possible.
I would like to stroke the block on this one but been reading about problems with cams and the 700r4. I am eyeballing the zz4 short block that is available for 2500
Yeah I want like three different cars, so I think I'm gonna get three c4s. Maybe one with a six speed stroker motor with large cam, and just keep my 87 stock on the cheap as a shrine to my younger days. I got the shop space for all of em! I might even have to pick up a c5 if they can just get a little bit cheaper, price is finally creeping down on those
Received 3,043 Likes
St. Jude Donor '05
If a stick and ls is what you want get what you can for yours and move on
If you want a stock rebuild your crank can be ground, heads rebuilt etc
Still betting a goodwrench crate from Jegs or Summit will cost less and last longer. They are pretty cheap.
If you were in love with your C4 then hard to look at it like its only worth but this costs? It its what you want then its worth it
Thrown more than 1 paint job on a 5000 truck over time was worth it to me. Everyones different.
C5s are getting cheap make damn sure it has no electrical issues esp up to 00/01? Some of those pieces are no longer available.
Like the C4s tons to choose from and they arent rare collectibles have at it.
Yeah it would for sure I just figured I got the shop and the space so why not, I'm gonna spring for a more high dollar driver and commute in it like I use to back in the day, that one will be an automatic. I was just thinking of getting a 6 speed cause some of the guys tell me that a manual is better for a large cam car. My old 87 has sintemental value and will stay with me till I die. I think im just gonna pull the motor on her and play with her for a while, get her running as cheap as possible, she will never be a Dailey driver again.
