I'm screwed
I'm screwed
Put my car in storage and went to visit it yesterday. When I originally stored it, I disconnected the battery and locked the hood, doors, and trunk (I have a Vert). Tried to use the actual key in the rear lock cylinder only to find that the cylinder is loose, and I can only put the key partially into it. Even if I can fully insert the key, I am wondering if I can rotate it to pop the trunk lid.
Any helpful suggestions are welcomed.
ajn
ajn
Sometimes you can leverage the key to try and pull the locking mechanism front and back to get it down a bit lower so you can turn the key and unlock. Bumper has to come off to get at it if it's not seated at all.
You could jack the car up and if you got like a jumper pack get a wire to the 12v lead on the starter and ground and should have enough voltage to open the door and trunk.
Red Rochester (03-01-2017)
ajn
Wondering if there's some way for you to get a grasp on the cylinder itself so you can hold it and get the key inserted fully. Even if it means temporarily supergluing something to it so you can hold it? I haven't crawled under and looked at that key slot to see what is exposed that might allow you to do that.
^^^ The key is built into the fob. The only keyslot on the car is the one he is trying to use, for the trunk.
Last edited by Steve Garrett; 02-24-2017 at 03:00 PM. Reason: No need to re-quote the previous post, especially if you're the next person posting.
^^^ Damn it! I guess I'm going to have to crack open that owners manual. This is the downside of buying from an out of state dealer. I didn't get any dealer orientation on the car. It would be nice if one of the large internet dealers made some orientation videos for us out of state customers.
Last edited by Steve Garrett; 02-24-2017 at 01:46 PM. Reason: Merged Posts-please use the Multi-Quote button in the lower right hand corner (middle icon) to make your reply look like this.
Why not just try it to find out?
Last edited by Steve Garrett; 02-24-2017 at 03:01 PM. Reason: Merged Posts-please use the Multi-Quote button in the lower right hand corner (middle icon) to make your reply look like this.
I think this thread, including the OP's comments and some of the replies, is a good wake-up call to owners to learn how your car operates and to check basic stuff like if that key works. I had a Chevy truck that developed a flat halfway between WI and NC (stuck in the boonies of KY) while I was towing my track car. You have to use a long rod to lower the spare tire down on the PU, and it wouldn't line up. I couldn't get to my spare. It kind of sucked. Oh, and Chevy roadside non-assistance wouldn't answer the phone.
Anywho - to the OP: why not just turn the freakin' key in the lock? At this point, what do you have to lose? If it doesn't work, you're no worse off. Sounds like you'll be due for a tow to the Chevy dealer.
Skid Row Joe (02-25-2017)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
To the OP, most don't know this, but that cylinder AND key are very stiff to boot---better to loosen it up and make sure it works before you need to use it. So, when you eventually get it working, stick something like WD or your fave in there, and work the key back and forth several/many times. When you first do it, it'll feel like you're going to break the key. Hopefully, you won't. Good luck.
Funny how threads get off topic, let's help the guy open his car. 12v to the starter should make the fob work. Or, fully insert key in trunk lock and turn key slightly then pull into position and open trunk.
The following 4 users liked this post by hope2:
This won't help this time but next year if you can't or don't want to leave you hood open you can take some strong mono-filament fishing line, tie it to the door opener in the trunk and thread it out the back of the car. Battery disconnected or flat, pull the line to open the door.
The following 2 users liked this post by dndrsn:
GriMacE912 (03-05-2017),
the solution (02-26-2017)
St. Jude Donor '10-'11-'12-'13-'14
