1968 400 3x2 cam
Old 02-25-2017, 12:14 AM
Duffeball
Duffeball's Avatar
Default 1968 400 3x2 cam
Hey guys,
Got a 68 I'm doing a rebuild on. Frame is nearly back to a roller. Gonna get an engine together soon. Just wanted input on the engine goin back in and if there's any point to giving it any "upgrades".
It's a 427 that's a 3x2 400 HP. Stock 215 heads with forged 6223 crank hypereutectic Pistons. Nothing fancy. M-20 4 speed and 3.36 gears. I plan to build it as normal but didn't know if anyone's messed around with a different cam in a standard set up? What were the results? I'm of the opinion to just go standard grind.
Still want to have enough vacuum produced to run the features of the car that need it.
Old 02-25-2017, 01:37 AM
ddawson
ddawson's Avatar
Before I had mine rebuilt is was a pretty standard 427, Q-jet and a compcam.
Also had headers. If the heads are still stock you could have them upgraded. Take a look at how Mark does it.
http://www.chevelles.com/forums/13-p...-pictures.html
Old 02-25-2017, 02:39 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
If you plan on keeping the car for a long time and you have some spare 'coin' to drop on the engine, you might consider a spunky roller cam.
Old 02-25-2017, 07:42 AM
Duffeball
Duffeball's Avatar
Default Keeper
To me it's a keeper car kinda deal. That said I'm even running the stock cast exhaust manifolds. The heads are already machined and rebuilt.
Maybe there's not a ton of value to upping the cam if everything else will restrict it on the way out.
Old 02-25-2017, 11:52 AM
ddawson
ddawson's Avatar
When I bought the car I had the stock manifolds. Still pulled strong but headers made a very noticeable difference.
Old 02-25-2017, 06:36 PM
rklessdriver
rklessdriver's Avatar
It would be well worth the money to put a retrofit hyd roller cam in the engine.
Will
Old 02-26-2017, 07:07 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
x2 dawson and reckless
The right cam headers and good tuning really wakes up a BBC doesnt take too much to have a good time
Edit: love the sound of solid flat tappets but HR is probably better long run
If you dont DIY Mark an excellent choice..or listen to Will hed never steer you wrong.
Old 02-26-2017, 08:17 PM
Les
Les's Avatar
Have you discussed valve to piston clearance with your builder? I don't know what kind of pistons you're using but the closed chamber heads make it important to know how much clearance you're working with, and that can determine how much cam you can use. Rollers, with their fat lobes, will hang the valves open longer than a flat tappet cam. Just something to think about.
To 1968 400 3x2 cam
Quick Reply: 1968 400 3x2 cam
