04 corvette
04 corvette
Alright so i decided to pull motor and forge bottom end this winter to get ready for a supercharger....everything went pretty well as far as the r&r i feel like everything is as it should be...got my baseline tune started car and immediately had a service abs and traction control light on...code is c1233...i have checked and double checkedmy wiring and cant find anything pinched or messed up anywhere...had an alignment done today hoping it would fix problem but no such luck....any thoughts on this issue something i am overlooking or need to try? Any help would be great car is running awesome just tired of idiot lights in my face
St. Jude Donor '13-'14-'15
C1233 is for the right front wheel speed sensor Not directly related to your engine work at all---UNLESS during the R/R you accidentally unplugged or fouled the RF wheel speed sensor circuit-----The wheel speed sensors are used for 2 things
1 The ABS uses this data to prevent the wheels from skidding on a hard stop
2 The traction control uses the data to prevent the rear wheels from spinning on a hard launch---( when TC button is ON )
Location: If you don't weigh in you don't wrestle Road America
My guess is the ABS jumper wire is bad (the jumper wire connects the wheel speed sensor - wheel bearing - to the chassis wiring harness). Here's a quick and easy way to check the harness take the LF harness off and put it on the RF wheel, take the RF wheel harness and put it on the LF. If the code changes to a c1232 then you know that the issue is with the jumper harness - if it remains a C1233 then it's more thank likely the wheel bearing.
I have seen once where the issue was in the ABS module but more often than not it's either the harness or the bearing.
