Thumping after Brake job
I recently did pads and rotors on my 07 z51. Ebc rotors with carbotech pads from ampd.(great company btw). Now I any time I apply the brakes anything past 15-20% I get a thumping knocking noice that slows down as the car slows down. I can not seem to pin point if its a certain wheel.
Does any one have any idea what the cause for this may be or were I can start looking. There is no vibration or kick back in the pedal its just a very annoying noise.
Supporting Vendor
St. Jude Donor '11,'13
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
blackz151 (02-26-2017)
sounds like the rotor is hitting something , is there any chance one of the rotors had a defect on the surface...
since it slows with speed...its definitely rotation related....take it apart and see of there are any defects on the rotors.... i would think that with a thumping like that you might be able to see where two things are making contact.
any chance that theres some debris or something sitting under one of the rotors..
i didnt even think of that.... the drilled rotors on my 540i are quiet under normal braking..but if i really clamp down on them i get like droning from the holes in the rotors.
