C6 Vert questions from potential buyer
Hi Forum members...
I am a former C3 vert owner and am in the process of looking for a C6 vert...
I'll be looking for a low mileage car with manual trans, black top, and black leather interior... Exterior color a bit more flexible...
Is there anything to look out for on the specific years? Any options that are a problem?
Thank you all in advance for any insight and experiences you can share...
...Dave
...Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16
Buy it if you find it
You may find that the convertible with a manual transmission is not all that common.
Most Vetts the last few years have come with the automatic.
I wanted a VY GS. Found out that there were only 81 VY GS made in 2013. Since there were only 18.4% GS with the manual trans, it came down to the possibility that my car was one of 14. Obviously, if I wanted it, I had to jump on it. Good luck.
LOL, I own your desired car. As stated the newer the more difficult to find manual transmission. To top it off I found a 2012 base with all of the above which I would almost guess that mine could be one of one...
Newest lowest mileage that you find is best. I had an '05 with no issues other than I broke the radiator support. I haven't had the '12 long enough to have an issue.
Good luck in your hunt, I bet you will come across it eventually.
I must be really lucky. When I was looking for a GS two years ago, I test drove two black 2011 GS convertibles M6 and a white 2012 GS Conv. These were all in the St Louis area. I couldn't find one that didn't have a black interior.
I see 11 GS convertibles with a manual on Cargurus right now.
Hi Forum members...
...Dave
...Dave
Check post 12;
https://www.corvetteforum.com/forums...for-my-c6.html
No specifics on convertibles, but here's a list worthwhile looking at before your purchase..
Check post 12;
Check post 12;
1) Buy a convertible that has always been garaged. If the car has lived in the south or western U.S., UV exposure can really age the top.
2) Seek a car with 1SB (2005-2007), or 3LT (2008 onward) options so that you have the POWER top. In theory, getting out to drop the top is pretty easy. But: you will enjoy many more hours of top-down driving by knowing that you can stop and get that top back up in a few seconds without getting out, opening the driver's door near traffic, etc.
3) A C6 soft top in good condition doesn't leak. You don't need to overlook stains or mildew as part of life with a C6. If the car has those issues, pass.
4) Same with air noise. The C6 soft top doesn't scream air. In fact, the vert is quieter than the coupe.
5) Scrapes or wear on the rear edge of the top (below glass rear window) is usually evidence of adjusting straps near the bows (upper frame) that need to be tightened. This is an easy adjustment. Brush marks near the sides of the top above the side power windows are normal - it's where the top folds against itself during the stow maneuver. Some wrinkling behind the power windows is also normal (stowing folds). These relieve after a good wet wash and dry with the top up.
6) All convertibles are more cool than all coupes. Yep. But.. you cant race 'em.
Happy hunting. Great, fun cars!!
Hi Forum members...
...Dave
...Dave
The convertible liner has a tendency to tear from the roughness of the metal frame catching the fabric as the top travels. If not too bad the metal can be sanded smooth and add a soft velcro strip to the area.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Just to add to the above: in the best condition. The reason for the first one (newest) is because every year---and sometimes, even during the model year---brings new improvements. Some of them are small, and not talked about, and some are much larger. But, the old "discussions" about the LS2 engine vs. the LS3 are not material. The same can be said for the A4 vs. the A6 transmissions, altho the manual trans did improve over the years from the T56 to the TR6060 with internal improvements occasionally.
Received 3,626 Likes
2016 C6 of Year Finalist
C6 of Year Finalist (stock) 2019
Always check the harmonic balancer to make sure there is no bad wobble of noise. Check the inside tread on the front vs the outside tread. Both are not small costs you could incur or have a bearing on what you pay. With low mileage you shouldn't have to worry about these, but if tires are wearing uneven you will have to sooner and that might involve 4 and not just 2 . Good luck
