C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Anyone powder coat the OEM fuel rail?
Old 02-26-2017, 01:52 PM
Michael_D
Michael_D's Avatar
Default Anyone powder coat the OEM fuel rail?
I'm going back to the OEM fuel rail when I install the MSD intake... Was planning to just paint it black to match the intake, but now I'm thinking about having it powder coated. I really don't know much about powder coating.. I'm betting someone else here has already done this??
Old 02-26-2017, 07:28 PM
tdeweese
tdeweese's Avatar
Michael,
Yes Sir I have Powder coated (2) of them and going to powder coat another satin black to compliment my Mamo Ported/Painted MSD intake. Cost you about $50
Old 02-27-2017, 12:18 PM
Michael_D
Michael_D's Avatar
Great!
I need to find someplace to send it to....
Did you coat the quick connect fitting area? (Not sure what else to call that, but I'm sure you know what I'm referring to.....)
Old 02-27-2017, 01:09 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Schrader valve...and you'd most likely want to mask the threads/end.
Edit...unless your talking about the fuel supply end. You'd want to mask that as well.
Old 02-27-2017, 02:23 PM
MTBSully
MTBSully's Avatar
I'm probably just going to paint mine
Old 02-27-2017, 02:29 PM
Michael_D
Michael_D's Avatar
LOL.....the fuel supply.
Old 02-27-2017, 03:13 PM
MTPZ06
MTPZ06's Avatar
I figured you probably knew what a Schrader valve was...but it was still morning for me, and I don't drink coffee.
Old 02-27-2017, 06:19 PM
tdeweese
tdeweese's Avatar
Great!
I did not coat the quick connect fitting.
Old 02-27-2017, 06:25 PM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,087 Likes on 573 Posts
If you got an oven and buy the small kit from Eastwood then you can do it yourself.
MTPZ06 (03-01-2017)
Old 02-27-2017, 06:30 PM
Michael_D
Michael_D's Avatar
I had no idea this option existed!
Old 02-27-2017, 06:32 PM
Undy
Undy's Avatar
Yep, once you buy the application kit then all you need to do other items is the actual media. Just google eastwood.
The following 2 users liked this post by Undy:
Michael_D (03-01-2017), Pounder (02-28-2017)
Old 03-01-2017, 12:44 PM
Michael_D
Michael_D's Avatar
Thanks Undy. i've been watching a few videos and can't believe how simple this process is.... I'm eye-balling all kinds of things that I could coat.
Old 03-01-2017, 12:50 PM
MTBSully
MTBSully's Avatar
Just watched some of those videos as well. it is tempting! I need to do my brake calipers, and could do a lot more if I bought the kit!
Old 03-01-2017, 08:47 PM
Undy
Undy's Avatar
You could even do those Kingsbury thrust bearing housings...
Old 03-02-2017, 12:19 PM
Michael_D
Michael_D's Avatar
Not sure if my oven rack would hold the weight.... Good timing though, I'm in the middle of converting our last machine over to tilt-pads bearings, and was just inspecting the thrust pads.
To Anyone powder coat the OEM fuel rail?
Quick Reply: [Z06] Anyone powder coat the OEM fuel rail?
