Borgeson streering shaft
Old 02-26-2017, 08:43 PM
mpro71vette
mpro71vette's Avatar
Default Borgeson streering shaft
When installing the borgeson steering kit how many inches do you collapse the steering shaft? I read that if you go to far its hard to go back.
Old 02-27-2017, 03:50 AM
terrys6t8roadster
terrys6t8roadster's Avatar
Approximately 2". All are different and yes do not push in to far. I put the new gear in, held the rag joint about where it belonged to get an idea of how much the shaft needed to be shortened, the put some tape on shaft. Removed the gear for access then pounded the shaft in up to the tape line. I used the old rag joint to pound on. T
mpro71vette (02-27-2017)
Old 02-27-2017, 12:27 PM
mpro71vette
Thanks!
Old 02-27-2017, 03:59 PM
BLUE1972
BLUE1972's Avatar
Received 1,124 Likes on 732 Posts
If you can soak the shaft with penetrating oil and then clean it / polish it - it's easier to move. This will also make adjusting much easier.
I found cleaning the teeth on the end of the shaft with a small wire wheel also helps get the new rag joint on.
Old 02-27-2017, 04:15 PM
Kevin68
Kevin68's Avatar
I've read that too but fortunately never found out if that is true.
This is correct except don't start with pounding. A few taps with a rubber mallet is all mine needed...and maybe yours.
To Borgeson streering shaft
Quick Reply: Borgeson streering shaft
