Headlight motor removal ?
Trying to get to the headlight motor on my 04,, got as far as the 2 hinge bolts and the torx heads are both stripped ,, is there another way to get the headlight out of the way ? Thanks
I've always had the same problem that you are having - so I remove the entire frame by removing the bolts on the frame below and the two bolts that hold the assembly on to the wall. Hope this helps.
While a pain, you could try coming up from underneath the headlight. Remove the screws holding the plastic piece in front of the wheel, slide / remove the brake duct out of the way, and you should have access to the motor.
Received 19,232 Likes
'20-'21-'22-'23-'24
Thanks for posting this info. Keeping it on file should something similar ever happen to my car.
