clutch pedal extension
did the clutch pedal change after 1990, This part shows 90 and up
https://www.corvettemods.com/C4-C5-C...html?pid=10107
im 6ft but when I put the seat all the way back where I am most comfortable, i just miss being able to fully press clutch to the floor which you have to do with the 6spd ZF
BV85 (02-28-2017)
Received 3,043 Likes
St. Jude Donor '05
You could always have someone weld a pedal stop higher up on the pedal and have it modded so its closer to you so youre not overextending the slave.
Or a block of wood.
Or a block of wood.
I can do lots of things, was just curious if anyone knew what the difference was or if there really is a difference
thanks anway
thanks anway
