Heater core remedy
Heater core remedy
Well, after reading all the posts from pass to present, I discovered that the Best and least expensive way to resolve "factory core VS repro" is to have radiator shop recondition the original core for $25.00 and be done with it. It fits, no muss no fuss and cheaper that an aftermarket.
D
D
D
D
bought an aluminum replaceemnt that is not as thick, from RockAuto.com and got it for 50 bux.....not finished hooking it up yet, man what a BITCH of a job....been on it for 3 daze now, 4 hours/day is about all I can do anymore.....
I just bypassed mine and never looked back. My car interior runs hot even after applying the heat barrier under the carpet. No heater needed even when I need defrost which is not that often.
Someday I may pull it and I have a good radiator man that says will repair it for me.
Received 1,469 Likes
Cruise-In II Veteran
For $25 all they would do is fix a small hole, not recondition/recore a corroded core.
