anyone use this tool?
The dealer has quoted labor to install plugs & wires at around 260.00. I have done quite a bit of wrenching on my coupe and feel pretty comfortable with doing it myself. I found a good pictorial on the process but they show a curved handle 3/8" flex head ratchet that made the install a lot easier--however , that tool is no longer available and this one is. Has anyone used this one and how did it work for you?
I know there are other more expensive curved ones available but with a 20% off coupon this would be much easier on my budget.
Any feedback is appreciated.
http://www.harborfreight.com/3-8-eig...het-96369.html
lonerider2002 (02-28-2017)
That looks pretty useless to me
I use a spark plug socket that has the swivel built in on a couple
of the cylinders..
The plugs really aren't bad to do.. Just be patient
of the cylinders..
12" to 14" long needle nose pliers ...two, one straight and the other with an angle. For the new wires and shields. The plugs are not a problem....coming out or going in.
The following 2 users liked this post by runner140*:
Dahc (03-01-2017),
1/4 mile/AutoX
Knuckle buster, I like the swivel head !! 25 years using one !! I bought this one from Lowes thought it look like Snap On, found out that's who makes them for Lowes !! Do yourself a favor and buy a good one for life !!!
https://www.lowes.com/pd/Kobalt-3-8-...atchet/3387120
Mike98SilVert (03-01-2017)
I've learned that it's best to be fully prepared so I'll probably get one just in case. Being that it's pretty cold here in Va and I need to pull the EBCM and send it off I'll just do a couple of plugs at a time to help keep the aggravation factor down.
http://www.iammoon.com/c5tech/c5_plugs.htm
ArmchairArchitect (02-28-2017)
Received 19,226 Likes
'20-'21-'22-'23-'24
Really the only plug that was a bit difficult for me was the #7 and that was tackled with some extensions and swivels. A plug boot puller helped a lot with the wires.
Yep--2.35 hrs @ 110.00 per hr. -- they will let me buy the items though. They do an oil change(me bringing the oil/filter) and a state inspection and I've set aside a "fund" for my Vette for this type of work but I'd rather put the dough back in my pocket. I might do as many as I can one at a time and let them do the tough ones...we'll see...
By the Pittsburgh or whatever its called at harbor freight. If it breaks you can return it just like anyone else you pay 2-3x more for. I haven't had one break and I use the crap out of my tools ask anyone or any of my cars or friends cars lol.. I just used a 3/8 and a extension and a swivel I believe. Whatever you do don't pay a dealer to do it.
I used two different swivel ratchets for weird spots. My '08 VW GTI was so tight spaced in a lot of spots so I had to use these with the given space. It's worked out well in a few spots on the Z06.
And
And
Why does everyone think the job is so hard on these cars? I did twice without anything other than a spark plug socket, an extension, and a ratchet. Its supposed to start raining here later today, I might just go tempt luck and swap them out again and race the clock.
1/4 mile/AutoX
I know, Right ??? one of the easiest I have done ?? try a 428 in a 69 Mach One !!!!
Received 3,036 Likes
However, I changed my plugs and wires when I installed my headers so it was an easy install.
