Paddle shift?
Paddle shift?
I think I'm within a month or so from being ready to purchase a C7. When I bought my C6, I was picky about wanting a manual transmission. I have no interest in an automatic. In my limited exploration of the available used C7's, I keep seeing the paddle shift in the description and it seems that it's always listed when the car is listed as an automatic. I'm completely unfamiliar with driving using paddle shifters...can someone shed some light on it for me or direct me to the appropriate link if it's already been discussed as I'm sure it has? Do all C7's have paddle shift? Is it always listed as an automatic? Where is the crash course on how to drive using paddle shifters? Any input is appreciated and I apologize if this has already been beat to death.
Google is your friend.
Received 1,738 Likes
St. Jude Donor '15-'16,'18
It's really pretty simple and foolproof. Right paddle to upshift and left paddle to downshift. Car will not let you shift if RPMs will be too high or too low. EZPZ.
Received 1,875 Likes
2020 C8 of the Year Finalist - Unmodified
Just Automatics.... you can drive the car in "D" for fully automatic mode and not even think about the paddle shifters..... OR, you can use the paddle shifters ANYTIME while in "D" automatic mode to downshift, or upshift. Lastly, you can put the transmission in "M" for manual, and then you need to use the paddle shifters to up shift and downshift.
Tons of fun, if you wish.
see this YouTube
see this YouTube
So if I purchase an automatic (my teeth grind just typing that thought) I essentially get both auto and manual, with the difference in c6 manual vs c7 manual being paddles on the wheel. I saw a youtube video of a manual transmission (7 speed) and the guy used paddles for revving purposes. I didn't quite understand the purpose.
don't forget the obvious ..... NO clutch pedal. So, yes you can manually shift up and down if you choose, but don't need to fool with the clutch.
We had 6 or so Manual Vettes in a row, and with the 2016 Stingray, decided to give the A8 a shot. When GM Engineering bought our '16 back (Warble analysis car) we had the choice once again, as we ordered a Grand Sport..... went with the A8 again. NO regrets, but to each their own. Was a very welcomed change. Don't miss the manual at all.
Looks like I need to get some seat time behind each one and determine for myself what I like! Thanks for the input. I welcome more if you guys have more to offer.
On the M7 manual transmission, you have the same paddles, but all they are is just an off and on switch for the Rev Matching feature. If you have driven manuals for some time, you may know about "Heel and Toeing" which raises the engine RPM to match the gear you are downshifting to so you don't upset the balance of the car. This was more important when our gearboxes were non syncro boxes or on race car transmissions. If you ever watched the old F1 races back in the 60's, you would hear a blip of the throttle right before a downshift into a turn which was the tell tale between a good driver and a great one. Trust me, it takes years and skill to get it just right. But the Rev Match does this automatically and perfectly without heel and toeing which is a really neat feature.
I understand that about 80% of all current Corvettes sold are automatics. But the A8 is the same design as what they put in Tahoes and Impalas. It is not an instantaneous shift, there is a delay between you applying power and it getting to the rear wheels, the computer will over ride your commands if it decides to, and if you expect it to be the same or better than the feel of a manual, stick with the manual. Needless to say, I ordered my GS with a manual.
Just a FYI, the paddles on the M7 turn the rev-matching feature on and off. They do look the same as the A8 paddles but do not serve the same function.
I have an 8 and really like manual shifting. Worth trying out. If you are in D and shift the car will revert to D in a short time. M Shifts differently at different RPMs, so play around a little to see what you like. Also, it will automatically downshift, even in M mode, if you slow up and neglect to shift. Personally, I like to downshift myself for curves but just let the car downshift if I am coming to a stop.
Definitely get some seat time in the A8 and test out the paddle shifters. I personally don't like them. Why? Well it lacks neutral. Many times I'll put the shifter into neutral and coast down a long low decline on the freeway. Also the shifting, for me, is not the same experience. Some have reported they hit the paddle and the shift doesn't happen immediately because the tranny says the RPMs aren't exactly right. Have you never driven and auto that say has the up and down "shifts" on the shifter. I had one in an Eclipse. Never used it.
As for the paddle shifters on an M7 - I have an M7 - they activate Active Rev Match. They are simply an on/off switch. With Active Rev Match on the system matches the RPMs to the speed that you are going. Essentially this an is automatic heel/toe thing. I find this works best on winding roads in the mountains. So when, say, you're heading into a turn and downshifting to 2nd at say 40 MPH, the engine will rev the RPMs to whatever 40 MPH is in 2nd as you push the shifter into 2nd. The result is perfect meshing and no engine braking. It's really quite nice. They just figured that since the automatics had the paddles they could repurpose them as Active Rev Match on/off switches.
Received 2,225 Likes
defaria,
While what you do is not a recommended driving practice, all automatic transmissions have NEUTRAL. And it can be selected at any time.
Baloney. At mid to high power the shifts are "almost" instantaneous with a paddle hit. And the only time the trans will not shift is if the car is going either too fast for the gear you want or too slow for the gear you want. And that's what you want it to do.
defaria,
There are some threads going around tips for using the paddles too, there are a lot of computer tricks like blipping the throttle that throws the car into more of a performance mode (haven't tried it yet) and some holding of the paddles on downshifts that will do some rev matching downshifts.
Additionally there is some folks that may guide someone away from an A8 due to potential issues going on with torque converters and/or rear diff's with warble (search for warble) that haven't been solved yet. Could be a warranty issue at some point and might be related to the V4 mode.
My feeling, you'll be very happy either way you go :-)
My fiance, at 4-8" could not push the clutch pedal all the way to the floor. So, we have an automatic. I was pleasantly surprised. Sure, the car doesn't have a clutch, but the shifts are fast, snappy, and very precise. We do enjoy driving our car in M about half the time we are out touring.
You will love either option!
I do have one and what you reported is baloney. Maybe you should report what you actually know instead of your interpretation of what someone else said.
I'm not exactly sure why you seem hell bent to tell me to shut up but I am 100% positive that I will not.
