440ci RHS complete motor turn key
This is my old engine, has made upwards of 1750rwhp but kept at 1200 and pump gas since it's most recent rebuild 1500 miles ago>
I am selling it to build something different with a larger power goal.
Here's what is included, all it would need to run is a computer and exhaust manifolds
Motor
• 440 cubic inches 4.125” Bore 4.100” Stroke
• 9.2:1 Compression ratio
• RHS Race prep aluminum LS Block- Standard Deck
• Callies Billet Crankshaft 58X Reluctor wheel
• Callies Ultra I-beam 6.125 Connecting Rods
• Diamond Billet Piston Set, Gas Porting, Pin set, Double pin oilers w/ slots, Hard anodized coating, oil rail supports, H13 wrist pins
• Total Seal Custom Ring Pack
• Calico COATED Main Bearings, Rod bearings
• Camshaft: 242/248 0.723int 0.731exh 116 LSA
• Katech C5R Timing Chain, Billet Upper/Lower Timing Gears, GM LS7 Timing Chain Dampner
• ATI SFI Dampner
• ARP Cam Bolt, Crank bolt, Head Stud 6 Bolt pattern
• Edelbrock Single plane intake
• Nick Williams 102mm Throttle Body
• MAST 315 LS7 6 Bolt Square Port Cylinder heads
• PAC Racing Dual Spring Kit, Ti Retainers, Seats, Seals, Locks
• T&D Shaft Mount Adjustable Rockers, Stands, Hardware
• Inconel Exhaust Valve Upgrade, Titanium Intake Valves
• Morel Mechanical Solid Lifters
• 3/8" Hardened Pushrods
• Cometic Custom MLS Head Gaskets
• GM Block Kit-Plugs, Dowels, Fittings
• Melling Hi Volume Oil Pump for LS Engines
• LS Series Oil Pan Gasket
• GM Front Cover Seal, Front Cover Gasket, Rear Main Seal, Rear Cover Gasket
• Vengeance Racing Custom Vented Breather Tank Assembly 1qt
• NGK 8 NON Projected Tip Spark Plugs
• Amsoil Dominator Racing Oil, Wix Filter
• Pfadt Solid Engine mounts
• VR Custom valve covers, Gaskets, ARP Hardware, Coil Pack Relocation
Close to 40k in this. Would sell for 18k.
PM me an email address so I can send you the invoices documenting the parts used
Thanks guys
Motor
• ATI SFI Dampner
Thanks guys
