76 Stingray Starter Issue
Cruising
This is my first post here and I've been battling starter issues on my 76' for a month now. After 3 different starters, I've settled with a new one from Nappa, got it installed (verified gap between starter gear and flexplate), and when I go to crank I receive the god awful humming/grinding with what sounds like engagement with the flexplate teeth but there is no cranking. The flexplate teeth all look fine, I pulled and bench tested the starter yesterday (passed) and I'm just about out of ideas.
Please help!
Please help!
Try using a different brand.
I bought a starter no brand name listed but it came from the blue and yellow sign LOL. Anyway had 3 within a month in the car. Finally I went with a Powermaster and its been fine ever since. (probably just jinxed myself).
dgshelto (03-20-2017)
Cruising
Do you happen to know which starter you bought from Powermaster?
What engine, flexplate, Trans ETC. do you have installed? Is this a new problem, did the original starter you removed have this problem?
Cruising
Flexplate: Not sure, probably should have just replaced it before installing the engine
Trans: Stock 4 speed..? sorry, not entirerly sure.
New starter, new problem. Previous starter (new from Autozone) was grinding pretty bad but would engage every once in awhile. Car towards end of complete rebuild, ready to hit the road once starter issue is addressed. With the new Nappa starter I haven't been able to crank the engine over.
Engine: V8 350 L-48 rebuilt, bored .040"
I don't think you have a starter problem, sounds like mis-matched parts or bad starter ring.
https://www.paragoncorvette.com/p-34...ring-gear.aspx
check the Fly wheel good. You may have some teeth ground down it maybe time for a new ring gear or flywheel. Also check that you have the correct starter 168 should be there not a 153 tooth. (but I am sure you know that)
The OEM starter worked great for about a year in mine then just gave up the ghost.
When I put in the "Blue and Yellow" starter is when I had a bunch of problems. They where new not rebuilt units.
As for which Power Master one I have... its a 9600 I do have 11.0;1 compression and its been fine with no issues.
Cruising
The teeth look good on the flexplate/flywheel, but it could potentially be the wrong one for the car, I'm not entirely sure (it came with the car when purchased... bad engine was pulled already).
Cruising
I'll take a slow-mo video this weekend to give ya'll a better idea what's going on...sounds like I need to provide more information. For reference the sound I'm getting sounds like this (which may indeed be my problem):
https://www.youtube.com/watch?v=QRs0...ature=youtu.be
I'm pretty sure there are no shims required when bolting a stock GM starter to a 350 engine that is bolted to a TH400 transmission using a stock flexplate. Easy enough to confirm this, lay your iPhone under the car, hit record than start the car.
Cruising
Shall do. I'll report back with a video and we can assess from there. If it is indeed a flexplate issue, do you have any guides on how to replace it?
Cruising
Shall do - I'll report back this weekend with a video and we can assess from there.
looking at the video it looks like the pinion is hitting the ring gear move the starter out to the holes for a168 tooth ring gear. the starter should be multi holed to do this
You need this information.
The straight across pattern is for stock 12-3/4-inch diameter flywheels (typically 283/327) and flex plates (Powerglide) and the staggered pattern is for the 14-inch diameter flywheels (typically 350/396/427/454) and flex plates (typical Turbo 350/400).
Rebuilt starters have often had the mounting surface cut when rebuilding to give a smooth, flat surface and as such, normally require some shims to space them out so the gear doesn't hit or isn't too tight meshing with the ring gear.
Cruising
other than counting the teeth... no
it looks like you have a high torque starter it should have a dual straight mount so it will fit both flywheels. you may want to check it out.
I do agree with this as long as its a stock starter...
Cruising
Are you saying that my 76' can accommodate either a 12 3/4" or a 14" flex plate? As of now my starter with the offset bolt pattern, which I take it is for a 14" 168 toothed flex plate, is either engaging/hitting the flex plate, so can I assume it's the 14"?
Make sure you are using starter bolts that are knurled. This helps align the starter as the bolt holes are not that precise. Also never reuse the old starter bolts as the knurl tends to wear over time.
