What parts do I need to complete my NPP Muffler project?
I'm schedule to pickup a set of 08 NPP mufflers tomorrow and I have the vacuum module, sothen what other additional parts will I need to buy to complete my NPP exhaust system project? And where can I buy those additional parts?
Thanks Boonie
Thanks Boonie
Not sure what vacuum module you are talking about, if you are talking about the factory original vacuum switch ... that's to much work ......
If u are retro fitting to a car that does not have NPP do a search on NPP IN A BOX , it will come with everything you need and simple instructions . I recommend using the alternate vacuum line routing down the passenger side instead of thru the tunnel , it is much easier to do
Dave
Dave
Their is a write up on here (https://www.corvetteforum.com/forums...ne-intake.html). Works great.
Yes and it was cheaper and no worry of vacuum leak and took all of 20 min to install and didn't have to crawler under the car.
Brandon619 (03-24-2017)
