Column Lock, no code/dic
Tonight my car had the dreaded column lock. I know the answer for this is to get a CLB and I do plan on getting one, but tonight was different. The car showed no codes, did not see pull key on DIC either. After trying a couple times, I finally heard the "buzz" noise unlocking it, but this was after the key sat in the ignition. Has anyone had this happen? again, i know I need to pick up a CLB, but this was weird. google didnt return anything.
Good information thank you. Yeah I was actively pulling it and I also pulled after it worked. It was definitely odd, as I expected a message or a code but nothing. Come to think of it, it's done this once before (no code, no message on dic) so I will definitely be looking into the lmc5. Thanks again!
