FS: Headers, Meth Kit
The only thing specific to a C6 is the washer tank and pump location. Everything else is just parts.
The puml mounts to the frame rail behind the drivers fender. It uses the factory windshield washer tank as the supply. I will provide one with the adaptor in it so you can keep your stock one. With a longer hose the pump could be mounted anywhere, but as you know not a terrible amount of room.
The injector goes in whatever intake tube you are using.
I ran a maf freq converter, but there are several ways to trigger. I would suggest calling Alky Control, or downloading the install instructions to have a look at what's involved.
I mounted the controller under the dead pedal.
I made 1k wheel on pump gas with this system with no issue.
Meth consumption was a question when I got into this. I didn't want to fill up every tank of gas and you most certainly don't. I drive hard and never had to fill it once. I keep an extra pail of meth at the house.
