I can't believe it was there - the tank sticker!!
Old 03-23-2017, 07:47 PM
Hud1086
Hud1086's Avatar
Default I can't believe it was there - the tank sticker!!
So I knew I needed to replace the gas tank, sending unit, etc, but what I didn't expect after 49 years was to actually find a readable tank sticker! The car is numbers matching but I had no documentation on it until this.
Can't wait to start looking more into her history and options now that I have this! Proud owner right now!
Old 03-23-2017, 08:22 PM
hummiscorvettetaken
hummiscorvettetaken's Avatar
Nice find
Old 03-23-2017, 10:10 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Stick it in an acid-free plastic sleeve. If you want to do more to preserve it, research 'Document Preservation' on the web or visit a document restorer.
Old 03-24-2017, 12:21 AM
CV62Air
CV62Air's Avatar
Wow! That was a great find. Very cool
Old 03-24-2017, 01:28 AM
jr9170
jr9170's Avatar
Location: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Received 1,069 Likes on 755 Posts
Old 03-24-2017, 06:44 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Sweet. You're very lucky!
Old 03-24-2017, 07:31 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi HUD,
What a NICE combination…. 350 hp, 4-speed, CONVERTIBLE, with 3.70 rear gears.
Someone knew just what they were doing!
Regards,
Alan
AND no radio!
I'd be interested in seeing the area where the antenna would have been mounted, from below… if the tank happen to still be down?
Old 03-24-2017, 08:15 AM
Don Rickles
Don Rickles's Avatar
2017 C3 of Year
A little hard to make the codes but if I read it correctly this MIGHT be helpful?
Here the results out of the dealer codes database based on the provided search criteria:
Zone Dealer Number Dealer Name
Show Dealer Details Change Dealer Details 18 92 Unknown
Show Dealer Details Change Dealer Details 18 92 BOB BROWN CHEVROLET INC
Old 03-24-2017, 09:32 AM
Hud1086
Hud1086's Avatar
Originally Posted by Alan 71
Hi HUD,
Regards,
Alan
AND no radio!
Alan, the strange thing is that there IS an antenna on the car. When I first got it I couldn't figure it out because there was an antenna on the back but no radio. Had someone taken the radio out and covered the place it had been?
Nope, looks like either at the factory they made a mistake, or someone added it afterward for some sort of system in the 'trunk' area.
Either way, I had no idea it had the M-21 and 3:70 gears!
Old 03-24-2017, 09:34 AM
Hud1086
Hud1086's Avatar
Thanks for this info! Today at 'the job that pays the bills' I will continue this research. I've hunted down 2 previous owners and traced it back as far as Chicago in the early 80's, but knowing the dealer would be awesome!
Old 03-24-2017, 10:03 AM
Alan 71
Alan 71's Avatar
Hi HUD,
The reason I ask is because I'm unclear if the opening for the antenna was cut on all cars and then 'patched' for cars without a radio, or if the deck was only cut for cars with the optional radio.
Regards,
Alan
Old 03-24-2017, 10:07 AM
Hud1086
Hud1086's Avatar
Hi HUD,
Regards,
Alan
I have the same question. When I get around to it I can take a picture of the hole and maybe someone with a radio can compare how it looks to theirs? I've had to 'tighten up' the antenna before, and it was an oblong hole that was pretty jagged, so not sure if that's how it was done on the line or if it would have been more smoothly cut from the factory.
Old 03-24-2017, 10:30 AM
gearheaddroppings
gearheaddroppings's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10
Hi HUD,
Regards,
Alan
My 1970 is original without a radio. Over my 20 years of ownership, this is what I have determined.
1. After stripping paint off of my car, antenna hole was present but filled (most likely at the factory). I have pictures of this if anyone wants to see.
2. The noise filter on the fan was looped onto itself and not installed.
3. No exhaust ground straps present. Holes in frame did not have bolts installed. Exhaust was most likely replaced in the 1970's, so not sure on what would be correct.
4. Uncertain about exactly what ignition shielding came with the car. The wire looms on both sides of the distributor were present. Guides say lower shielding should be present, but engine was rebuilt before I got car.
Old 03-24-2017, 10:43 AM
Alan 71
Alan 71's Avatar
Hi ghd,
I would be interested in the photo of the antenna area. I'm especially curious about the shape of the hole for the antenna.
I would expect a car without a radio to have the 2 distributor shield supports, the 2 spark plug wire guide brackets that bolt to the rear flange of the block, the 2 boom-a-rang heat shields,the 2 spark plug wire guides that attach at the oil pan, and the 4 spark plug heat shields.
Have you had occasion to look behind the dash to see if the other condensers that were part of the radio option are in place?
Regards,
Alan
Old 03-24-2017, 11:02 AM
raydog9379
raydog9379's Avatar
I second that. Don't just buy any sleeve. Find archival quality. I also collect historical documents. Clearbags is a brand I use. You can buy them at Hobby Lobby.
If you must tape the pieces, there is archival tape as well. It's expensive but don't use anything else on it if you feel like you want to tape some of the tears. It's called Transparent Mending Tissue and made by Lineco. About $6 for a little roll.
Old 03-24-2017, 11:10 AM
Hud1086
Hud1086's Avatar
Thanks for the tips. Sadly it's too late for the tape. In order to get the sticker off of the tank in one piece I placed a line of clear packing tape over the glue line so that when I took the razor blade carefully to the glue to remove it the print/paper would stay in tact and readable with the tape. Rookie mistake. Afraid that tape is not going anywhere now
Old 03-24-2017, 11:34 AM
raydog9379
raydog9379's Avatar
It'll probably brown out over the years, but that'll be a long time. Not sure if you can get it off without worse damage.
I'd make sure to keep it in the acid free holder and out of direct sunlight.
Sweet find btw, and sounds like an awesome car.
Old 03-24-2017, 11:46 AM
gearheaddroppings
Hi ghd,
Regards,
Alan
I have not had a chance to look behind the dash. I am almost positive there is no type of antenna wire present.
I will scan that old picture of the deck sanded with the filler present for the antenna hole and post it.
My car was a very strange order. PS, PB, A/C, M20, 3.55 rear, and no radio.
Old 03-24-2017, 11:59 AM
Don Rickles
2017 C3 of Year
With a quick review of previous years RPO production numbers, its clear that the bean counters knew, most buyers ordered radios. The leads us to assume ALL cars had the holes, and the occasional non U69 order would be filled. Could you see the time required on the line to drill out the majority of cars? I don't think so.
To I can't believe it was there - the tank sticker!!
Quick Reply: I can't believe it was there - the tank sticker!!
