Harmonic balancer / damper replacement
I have the dreaded wobble on my 05 with 50,XXX miles. Changed to a Gatorback belt and the chirp stopped but it's gonna be time for the a swap soon.
I have been looking for a good video to assist in doing it myself. Anyone have some good ones bookmarked?
Thanks!
Thanks!
You'll find a couple of damper install Vids on youtube.
Would not use GM damper use aftermarket and ARP bolt and follow their torque specs.
Replace front seal while your there.
I used ATI super damper. Your millage may very
a few tools you will need , you can find some rent free at your local auto parts store.
http://www.ebay.com/itm/Proform-6651...QAAOSw32lYn4Re
http://www.saccitycorvette.com/AlignItTools.html
8th Gear
Not a fun job
Good Luck
The k member will come down more it you loosen the shocks. It is possible to lower it enough to do the job with never touching the rack.
Good Luck[/QUOTE]
Has any forum member done that? If it could be done that way it would be a great time saver. And make a difficult job somewhat easier.
Good Luck[/QUOTE]
I braced the engine in position and lowered the subframe with steering rack attached. I disconnected the motor mounts, outer tie rod ball joints, and lower control arm ball joints. I also removed the anti-roll bar bushing caps so the bar hung down, detached the power steering cooler from the subframe, and disconnected the steering gear at the slip joint.
Afterward I had the car aligned but it didn't need it. The locator pins in the subframe do a good job of positioning it repeatably.
Crazy forces are required to remove and install the balancer. The factory flywheel locker is very much worth having.
That's how I did it.
Kind of sounds just as involved as the other way.
Thanks for all the help!
If or when I have to do this, the heavy work will be done by my son, a real gym rat....benched 350lbs....so I have that covered.
