ALDL Droid
Old 03-26-2017, 03:18 PM
billy mild
billy mild's Avatar
Default ALDL Droid
Has anyone noticed connectivity issues with their different phones? I have an old Nexus 7 tablet that seems to work great with ALDL droid and my bluetooth adapter. My Nexus 6p has all kinds of connectivity issues. Constantly drops connection to ECU and what not. Is this normal to vary from phone/tablet to phone/tablet?
Old 03-26-2017, 06:35 PM
QCVette
QCVette's Avatar
No problems here.
I bought one of the cheapest units (under $10 shipped) to try it out. It connects fine to my Samsung phone. No drop outs either. I haven't tried it on my '96 Corvette, but it works with my Impala and 300.
Old 03-27-2017, 06:04 PM
1993C4LT1
1993C4LT1's Avatar
I did have some funky connection problems when I first started using it, and didn't know wtf I was doing. Is your OBD port clean, and tight connection? If yes, I would try it on another android device and see if it still acts up. Are you sure you have the correct ECM file for your car?
Old 03-27-2017, 06:44 PM
aklim
aklim's Avatar
Received 2,234 Likes on 1,943 Posts
I'm curious. How do you have the right ECM file for your car if it is modified? I have a 91 auto. What would be the right file if my ECM has an EPROM that has been wiped out and reprogrammed?
Old 03-27-2017, 06:50 PM
1993C4LT1
1993C4LT1's Avatar
I always wondered the same since I got this. I would assume the tuner would have to send you the file they made, and upload it to aldl droid?
Old 03-28-2017, 02:05 AM
Cliff Harris
Cliff Harris's Avatar
The .ADS file used with ALDLDroid and similar programs is a simple text file. Easily modified if you know what you are doing.
Old 03-28-2017, 08:15 AM
aklim
aklim's Avatar
Some tuners don't like to do that. IIRC, one or two would scramble the thing in a way that it couldn't be easily read.
Old 03-28-2017, 09:05 AM
aklim
aklim's Avatar
Any difference between ALDL Droid and ALDL Scan?
Old 03-28-2017, 11:27 AM
1993C4LT1
1993C4LT1's Avatar
It's pretty much the same from what I've seen. Just that aldl droid is easier to read, you can put whatever readouts you want etc. And I believe better recordings of data logs. As in, better laid out. You could tune from aldl droid as well, but I have not fooled with that.
Old 07-09-2017, 10:44 PM
ryank9398
ryank9398's Avatar
ALDLscan "must be used with 1320electronics.com BT adapter". ALDLdroid may not be limited in the same way. I'm using ALDLdroid with moates.net APU1 autoprom USB connection.
FWIW - when connecting tunerpro on a laptop to datalog, there was a setting to adjust to help with intermittent connection.
Old 07-09-2017, 11:59 PM
-=Jeff=-
-=Jeff=-'s Avatar
1320 BT Adapter will work with ALDLDroid.. I have that adapter, it works with my Nexus 7 Tablet..
With my current Android radio the Bluetooth if particular and I need to use a cable..
ryank9398 (07-11-2017)
Old 07-11-2017, 08:51 AM
ryank9398
ryank9398's Avatar
Good to know, I was just copying what I read on google play.
-=Jeff=- (07-11-2017)
Old 07-11-2017, 08:58 AM
-=Jeff=-
-=Jeff=-'s Avatar
Also to answer the question of files to use.. While a tuner might have created a new BIN file with tweaks, it is based off of the model year you have. The model year is the definition
for example. .my 1990 ZR-1 uses a $8EA mask. so I have a $8EA.xdf (for tunerPro and ALDLDroid)
the XDF defines the parameters in the BIN file that is burned on your MEMCAL (Chip)
there is and ADX file, this is what TunerPro and ALDLDroid use to SCAN the parameters, the Tuners don't typically change this output. for my car I created a $8EA.ADX to scan with, which also will silence the CCM, I have created the ADX for all the ZR-1 years, as well as the 90-91 L98 and 92-93 LT1. Many here use my 92-93 ADX file for their cars.
Old 07-11-2017, 09:03 AM
1993C4LT1
1993C4LT1's Avatar
Very cool Jeff
Old 07-11-2017, 02:01 PM
ryank9398
ryank9398's Avatar
Jeff - while we are on the topic of creating a datastream definition would you please comment on how a person might have adapted an 7727 ecu to input data other than from stock sensors? For example, i've read about people trying to input their wideband analog in the datastream using the AC sensor sender or EGR analog location? How about teaching the ECU to interpret a 2 bar map sensor in place of the standard? Is this done with manipulation of the datastream?
Old 07-11-2017, 02:11 PM
-=Jeff=-
-=Jeff=-'s Avatar
Changing the datastream is somewhere in the BIN file mentioned earlier. I have heard about all you mentioned, but above my pay grade
meaning you need to find where the pointer is in the datastream code that points for the EGR, and change that to the unused input you attached the Wideband to.
the MAP sensor is also code changes in the BIN file
Old 07-11-2017, 07:14 PM
9T3VETTE
9T3VETTE's Avatar
This is some good info, thanks.
If I'm reading this correctly the ADX file that you created for 92-93 can be used to SCAN parameters regardless of what is burned on the MEMCAL? Meaning if one vehicle has a stock MEMCAL and tune, and another has an aftermarket MEMCAL piggybacked off the stock (i.e PCM for less mail order) they can both use the ADX file you created?
Old 07-11-2017, 09:05 PM
-=Jeff=-
-=Jeff=-'s Avatar
Yes. All that a tuner changed are variables for timing, fuels and other things. The main fabric remains the same. They are not redefining different areas of the file to use
The following 2 users liked this post by -=Jeff=-:
9T3VETTE (07-13-2017), ryank9398 (07-11-2017)
Old 07-11-2017, 10:51 PM
1993C4LT1
1993C4LT1's Avatar
Sweet! Been wondering the same for a while.
To ALDL Droid
Quick Reply: ALDL Droid
