wiring goes through fire wall???
Old 03-26-2017, 10:37 PM
Youngvettehunter
Youngvettehunter's Avatar
Default wiring goes through fire wall???
I need help. Were does the wiring that goes through the rubber grommet in the fire wall go to?
Old 03-26-2017, 11:37 PM
Tom73
Tom73's Avatar
Picture would help along with year.
Old 03-26-2017, 11:38 PM
bazza77
bazza77's Avatar
a little bit more information might help , like which grommet, where on the firewall is it , stuff like that.
Old 03-27-2017, 12:41 AM
henrikse
henrikse's Avatar
If you look under brake booster way down you will see the engine and light portion of the harness
Old 03-27-2017, 06:47 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Originally Posted by Youngvettehunter
...I need help...
The AIM can provide that.
Old 03-27-2017, 07:39 AM
bj1k
bj1k's Avatar
Everything forward of the firewall is for the engine and front lighting and everything from under the dash where the fuse block is goes to feed everything from the firewall back like the dash and rear lighting. The two harnesses can be split apart on the outside under the master cylinder by removing the center bolt on the harness and pulling apart.
Old 03-27-2017, 07:58 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi,
In addition to the forward lighting harness and engine harness that connect at the fuse block there are a couple of additional wires that pass through the firewall in grommets… the back up lights connection, and fiber-optics bundle (which looks like a wrapped harness bundle) come to mind.
Regards,
Alan
Old 03-27-2017, 08:55 AM
Youngvettehunter
Originally Posted by Alan 71
Hi,
Regards,
Alan
that is what im talking about. do you know how to remove them or where to unplug it in the car
Old 03-27-2017, 09:02 AM
Alan 71
Alan 71's Avatar
Hi,
For the back-up light connection the grommet is removed from the firewall so the wire and connector can be pulled back through the hole into the interior.
For the forward fiber optics the cables must be disconnected from the lens in the shifter console so the cable can be pulled forward through the grommet/hole into the engine compartment. Or, the cables disconnected at the lights and the cable pulled into the interior.
Regards,
Alan
Youngvettehunter (03-27-2017)
Old 03-27-2017, 11:51 AM
bj1k
bj1k's Avatar
Hi,
Regards,
Alan
Alan , I'm confused on this one. My wires for backup light switch on my 72 don't go through the grommets . The wires come off of the engine harness to a plastic plug . From there it goes under the firewall to the reverse switch on the transmission.
Old 03-27-2017, 12:56 PM
Alan 71
Alan 71's Avatar
Hi,
Typically:
The 4-speed back-up light wire is part of the dash harness. It has a SHORT lead and connector that comes through a grommet in the firewall. It in the same grommet as the oil pressure line and tachometer cable.
The back-up light switch on the transmission has a LONG lead and comes up in the transmission tunnel and makes the connection a few inches from the grommet.
Regards,
Alan
The lead coming out through the grommet is wrapped, but the lead going down to the switch isn't.
Old 03-27-2017, 02:02 PM
Youngvettehunter
Hi,
Typically:
Regards,
Alan
did u have a pic of the other connection as well?
Old 03-27-2017, 03:13 PM
Alan 71
Alan 71's Avatar
Hi yvh,
Which connection?
Regards,
Alan
Do you ever look at your Assembly Instruction Manual?
Old 03-27-2017, 03:19 PM
Youngvettehunter
Hi yvh,
Which connection?
Regards,
Alan
no not really i find it very confusing. I'll look at it again tonight.
Old 03-27-2017, 05:38 PM
Alan 71
Alan 71's Avatar
Hi yvh,
The AIM can seem pretty overwhelming… but there's a tremendous amount of information contained in those drawings.
Perhaps you could flip through it some evening to see what's there and how it's layed out.
Then when you have a question about how something was assembled you'll have an idea of where to look for the answer.
What connection?
Regards,
Alan
Old 03-27-2017, 08:22 PM
Youngvettehunter
Never mind I found it in the book
Old 03-27-2017, 09:18 PM
bj1k
bj1k's Avatar
Hi,
Typically:
Regards,
Alan
Alan , I stand corrected . I was looking at the wire behind the engine harness . It looked like it was coming out of the engine harness . When I pulled the engine harness out of the way , I could see the grommet that you mentioned . I should have remembered , I just recently wired the car. The brain cells are getting old .
Old 03-28-2017, 04:00 PM
Easy Mike
Easy Mike's Avatar
Good for you. The "book" can help quite a lot.
To wiring goes through fire wall???
Quick Reply: wiring goes through fire wall???
