Checking Coolant Level
Hi Rocket Riders !!!! I have a 2013 427 Vert and would like to check the Coolant Level. The Manual states If coolant is visible but the level is not at or above the " FULL COLD MARK " add fluid. Where is the "FULL COLD MARK ? My Tank has a clear bottom half ( and I can see Fluid ) and the top half is black but I can't see any FULL COLD MARK . The manual does not have an example . Where is the Mark ????
Thanks in advance , always a great knowledge base :
Pro Mechanic
Received 3,952 Likes
Fill the coolant surge tank with the proper DEX-COOL coolant mixture until the level inside stabilizes at the FULL COLD mark on the front of the surge tank.
Thanks rKj427 I went out and did find the FULL LEVEL mark on the front of the tank a very unlikely placement for it unless you know where to look ...... thanks
Pro Mechanic
have you posted the info. for your 427 on the 427 Convertible topic at the top of the C6 general area pages?
post up a picture and provide some details.........
