FS: Ccw classic 17 by 11 with Hoosier R7's
I can sell the rear 2 for 1150 or all 4 for 2000. They are for a c5 but I figured some of you guys run c5z06 wheels. I'm in Houston. Can text 7138943608
17 x 11 all the way around? What's the offset and back spacing? I'm assuming it's close to this?
Bolt pattern 5x4.75" (same as 5x120.65mm)
Front offset= +58mm, Back Spacing= 7.0" (177.8mm)
Rear offset= +65mm, Back Spacing= 7.5" (190.5mm)
Size of tires? Is the finish on the wheels worn out? Thank you!
