FS: Borla Carbon Fiber & Stainless Corvette C5 Exhaust
$150 picked up or I can ship UPS ground for an additional $50-$80. Located in Upland, CA 91786.
3" Stainless steel tubing, 4.5" polished stainless exhaust tips with "Borla" and cross flags engraved, wrapped in real carbon fiber. I've only seen these once before and that was on a Prowler. If you want something unique, these are for you!
The bottom of the tips have a flat spot from grinding on driveways (I never had this problem, they were on the car when I bought it). I had to grind the welds off where the over axle pipe connected to remove them but it doesn't affect how it works and you won't see it when mounted. You will need to re-weld them or buy some clamps to instal. The bolt for the passenger side mounting bracket broke and can be replaced or left as is.
This is a quality exhaust made by Borla. I didn't clean them before taking pics, sorry. Let me know if you have any questions, thanks!
