FS in SoCal: 2002 Black / Torch Red 1SB Corvette Coupe, 36k mi.
2002 Black / Torch Red 1SB Corvette Coupe 35,598 mi.
$18,500
5.7 liter V8 engine (350 hp / 360 lb.ft.)
4-speed Automatic with overdrive
Limited Slip Differential
Active handling system
Traction control
4-wheel antilock braking with power 4-wheel discs
Memory package
Tilt / Telescoping steering wheel
Driver and passenger airbags with child safety shutoff switch
Daytime running lamps
Speed-sensitive rack and pinion steering
Removable targa roof panel
Heated mirrors
Remote release hatch
Adjustable Sport 6-way power bucket seats
Leather seats
Polished aluminum 5-spoke wheels
Tire inflation monitor system
Power windows and locks with express down
Cruise control
Theft deterrent with alarm
Remote keyless entry
Rear defogger
Fog lights
Dual-zone air conditioning
Front/rear integral antennas
Day/night rearview mirror with map light
Illuminated covered visor mirrors
Courtesy lights Lockable storage compartments
Additional equipment:
• Custom leather interior (console, center stack, airbag, seats, shift boot, e-brake boot
• Custom double-din Kenwood navigation sound system with Bluetooth, HD radio, XM-ready, backup camera, 5-channel amp, 10” sub-woofer with remote level control, custom A-pillar tweeter mounts
• Triple heat and sound insulation throughout entire interior
• True HID projector retractable headlights
• NXT Step Stainless Steel Exhaust
• 3.42 Differential
• Yank 3200 Converter
• Transmission Cooler
• C6 Z06 Sway Bars
• Elite Engineering Rocker Rails
• Elite Engineering Insulated Tunnel Plate
• New water pump, new timing cover/gasket, new timing chain, new crank seal, new ARP crank bolt, new drilled and pinned crank pulley, new belts and hoses, starter heat shielding
• Llumar solar tint
• Painted fuel rail covers
• Red Top battery
• Polished engine caps
• Fog light cove and rear valence screens
• Enhanced front corner lights
• Tail light seals
Adult driven, meticulously maintained and tastefully upgraded, this 2002 coupe drives beautifully with the additional performance afforded by the upgraded differential and converter as well as the Z06 sway bars. The recommended maintenance has been performed regularly including brakes, coolant, engine oil, belts, hoses, transmission fluid, etc. The exhaust note is aggressive but reasonably subdued. The interior is upgraded far beyond the original stock condition with tasteful leather touches that bring a bit of luxury into the sporty cabin as well as a premium audio and navigation system with an automatically-engaged backup camera. The ride is controlled but very comfortable for even the longest trips with 6-way power seats including lumbar supports and ample leg and head room.
There are a few esthetic blemishes that are pictured. Also, new tires are advised as these are the originals and should be replaced.
Blems
$18,500
Traction control
Memory package
Heated mirrors
Leather seats
Cruise control
Rear defogger
Fog lights
• 3.42 Differential
• C6 Z06 Sway Bars
• Llumar solar tint
• Red Top battery
• Tail light seals
Blems
