Motive power bleeder 0108 - $40
I used to use this for my 2004 chevrolet corvette, but no longer need it. perfect condition, only used once, includes all original parts. below is the product description:
GM POWER BLEEDERTM Brake & Clutch System Bleeder Fits most late model GM cars and trucks Motive Products GM POWER BLEEDERTM Bleeder features custom cap to fit most late model GM cars and trucks including Cadillac, Chevrolet, Oldsmobile and Saturn. Also fits Mazda Tribute. Includes MP1108 adapter assembly. POWER BLEEDERTM Features: * Heavy duty 2 quart pressure tank holds enough fluid to do complete flush & bleed. * Built-in hand pump (no other pressure source is needed) * Precision pressure gauge ensures safe and effective operation. * Tested for compatibility with both standard and synthetic hydraulic fluids. All bleeders come with everything you need to bleed your hydraulic brake or clutch system and a full 1 year warranty.
Somebody get this!- The price with the adapter is a good deal. If you ever get stuck waiting for a helper to bleed brakes, this will solve all of that and it even saves you from wasting fluid like the 2 person pump method typically will. It takes longer to remove the tires than to bleed with one of these. If I didn't already have this same combo I would have bought it.
They usually go for around $60 if I recall correctly, so it's a really good item to pick up and is super handy to have in your garage.
Figures...I just bought one on Amazon over the weekend, but w/o adapter...and this is a better unit than the one I ordered. Where are you located? PM if you prefer. Thanks -
Barry
Barry
