Straight pipes
1st Gear
Straight pipes
I currently have corsa extremes on my 2011 base and i want to go a little louder is there a shop around chino hills or other surrounding areas that can put a straight pipe on for me or make one?
My nephew, put a set of straight pipes on his 2001 Z06. He got the pipes from Borla, and installed them himself in the garage, just using jack stands. The pipes come right off the Cats..and straight back. They have a wicked sound..not really that loud at idle or cruise..but when you stand on it, people turn around and think..."what the hell is that??" LOL Another thing..a lot of these manufactures exhaust systems like Corsa and B&B..really have a nasty drone at cruising speeds..you don't get that with the straight pipes.
Install a set of long tube headers with an off road pipe that will solve your problem.
Whatever you do, don't do both straight pipes AND longtube headers/X... I purchased my H/C/I Z06 in that configuration and the noise and drone was unbearably loud.
I'm running LG 1-7/8" Pro's to what should be the Corsa Extreme's as the catback (just bought the Extreme's from a forum member this week so they're on the way). I pulled my FLP/cutout/GHL and pulled the LS7 setup out for this final setup because that's what I really wanted all along. I'll be selling the LS7 setup and GHL's shortly.
I'm very tempted to add cutouts again as that was the sound I have liked the best, by far, of all the exhausts I've run on my C5 over the years. I had the QTP's welded in and I installed the rest my self many years ago when I lived in Atlanta. That was about 2004. All the fab work by the exhuast shop back then was ~$300 - definitely a bargain for all the work they did. IIRC, the entire setup, including the QTP's cost under $700 total.
Really? Hmm I just installed a set of C6 Z06 mufflers with my off-road system on my 2005 Coupe. This system is quieter than my stock system with B&B Bullets. Oh and not every Californiain has to smog
It's still illegal, whether you have to smog or not, and if you get caught, you're still going to get in trouble. So yes, really. Did you know that they set up emissions checkpoints now?
No I was born yesterday, with all sarcasm aside RJ the all knowing one. Those road side check points are voluntary yes voluntary. I've been there done that, been to the BAR for inspection so I have a little knowledge are California Smog rules. The reason for posting MY OPINION is to share my experiences on the subject. Thank you for the update on what's illegal and what's not.
Straight pipes
I assume your "really?" was directed at my comment regarding Cali and headers. If it was a response to my comment about longtubes with straight pipes causing done, your reply was even more off base, as the noise level of your car with headers and C6 Z06 mufflers would be expected to be quieter than my car was with headers and NO MUFFLERS (straight pipes).
Excuse me, but you're the one who called ME out regarding my comment about Cali being unfriendly to headers. Your condescending tone is completely unnecessary.
Straight pipes
Ok RJ, you talk/type like your schooling someone with your post this was reason of my quote/reply to your post. I'm not concerned about my edict on how I post towards anyone. Take a look at what you post, then reread my post. My reply was based on your quote plain and simple. If you don't like my opinion on how I navigate the California smog rules then that's your problem. Have a nice day.
