Figure out the problem. It wasn't a crack at the transfer tube like we expected. After dropping the tank, we found a hole in the top of the tank from a screw (you could see the thread marks in the hole on the tank). The previous owner had mounted something above the tank and drilled right into it. I very rarely filled the tank over half full so I didn't notice this until now.
Here are holes where something had been mounted previously. Offending screw hole circled. Racecar.
I will be there! Stock class... hopefully more guys sign up so its not just Donny and myself battling it out. Cough cough Lloyd. Tim told me to call you out don't hold it against me! haha
Got you down Jake!
Lloyd - The gauntlet has been dropped.
Jake!!, you hung me out to dry. Now Lloyd will come out and school both of us!!!!
