12:1 compression ratio on CA gas
Anyone running 12:1 on 91 octane for street car? Building an LS7 with a healthy cam and want to get some peoples personal experience with higher compression and tuning.
Platinum Supporting Vendor
Not gonna fly with the crappy 91 octane here in CA. Get with Ryne @ CMS and ask about getting it setup for E85 so you have enough octane for that combo.
Received 3,043 Likes
St. Jude Donor '05
Why risk it?
Running a little over 11.5 and can do it if needed but adding some VP 100 unleaded leaves more room for error. In the long run a little good stuff is cheap piece of mind. Our gas isnt the best esp the "summer blend". Sure miss the old 93..
Will the stock fuel system support ~600rwhp on e85? Im currently making 576rwhp on a stock LS7 (11:1) bottom end N/A with 91 octane.
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I'm running a 1970 LT-1 11:1 cr. I have to pull timing to run on Cal pump 91.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Have anyone tested the octane from this state? I honestly dont think it is 91. I say this because I've re-fueled on all continental states, and the second I cross into Arizona it feels the car "gains horsepower", ergo it's the California gasoline.
St. Jude Donor '05
Get yourself a drum of VP 100 unleaded mix 50/50 min wiht 91
Our "summer blend" is the worst.
I run 11.5 on 91 sometimes, if Im drving easy. On VP mix I can crank up the timing car transforms like it had a 50 shot on it.
I LOVE the cackle of a high compression NA motor, grew up around 12-13;1 cars nothing sounds like em...solid lifters sweetest music ever.
2017 C5 of the Year Finalist
St. Jude Donor '08
I run 12:1 comp on my my built LS3 C6. I run 91 mixed with Torco, and do have meth injection as well, but the car runs just fine...
Here's a track day from last year...
St. Jude Donor '05
Know this once I hit 190 deg it doesnt want to idle anymore and carb or fuel lines arent warm;anything less, sure all day long thats on a cam with 82 deg overlap....lots.
Theres something up with this garbage, many complain of the same thing. If I use a certain unnamed additive VP or the like its much happier. Ill say one thing gaskets dont like it very much have to replace them at least once a yr.
OP a big cam may bleed it off down low but when rpms and cyl pressure increase.....you need good stuff period. You spent a bunch on a great engine dont risk it for a few bux.
