Southern California Southern California
Weird noise from under the hood...
Old 07-22-2016, 10:41 PM
What Trust Fund
What Trust Fund's Avatar
Default Weird noise from under the hood...
Not too sure if its a belt issue or harmonic issue but it seems to stay consistent with the amount of gas i use the faster i go the quicker it clicks sometimes its there sometimes its not thats why i think its a belt problem. Any ideas? ill try to upload a sound clip if i can figure it out...
Old 07-22-2016, 11:19 PM
Dirty Howie
Dirty Howie's Avatar
Can't tell anything without audio. Hope its not a lifter.
DH
Old 07-22-2016, 11:55 PM
c6 monkey
c6 monkey's Avatar
I had a tapping one day when I started it. Was fine when I drove it the night before. Sped up with the motor, sticky lifter I think. I did some research and put a jug of Rislone in the oil. The tapping faded away in less than a minute. That's a $9.00 fix I'm sure the dealer would of loved to charge me 2k for, fuc# them anyway. If you want a picture of the empty can i can post that tomorrow.
Old 07-23-2016, 12:23 PM
What Trust Fund
Default listen closely you can hear the faint squeaking
https://www.youtube.com/watch?v=3ECd...ature=youtu.be
thats first gear only around 15mph
Old 07-23-2016, 01:57 PM
Dirty Howie
Well it certainly isn't anything bad, motor wise.
Maybe loose belt, alternator or AC pully.
DH
What Trust Fund (07-23-2016)
Old 07-23-2016, 02:14 PM
What Trust Fund
DH
know any shops or guys locally that will take a look for me? i live in chino hills!
Old 07-23-2016, 02:17 PM
What Trust Fund
Default heres a better sound clip
https://www.youtube.com/watch?v=AUSk...ature=youtu.be
that was this morning seems to be super loud when i first start it up
Old 07-23-2016, 03:49 PM
c6 monkey
c6 monkey's Avatar
Harmonic balancer, mine sounded like that it would fade away when the belt warmed up. Has yours been changed?
Old 07-24-2016, 01:23 PM
whalepirot
whalepirot's Avatar
Belts can mimic many other fault sounds. Tis easy to eliminate, spraying with belt dressing or WD, not too liberal application.
What Trust Fund (07-25-2016)
Old 07-24-2016, 05:08 PM
BOUT X
Corvette Cowboy
Support Corvetteforum!
BOUT X's Avatar
Sounds like belt tensioner or the tensioner for the AC belt or the start of the AC Compressor going out if you haven't changed your belts maybe change them and check all pullies and tensioners to see how they spin with no load. Just my .02 hope it helps.
Pops
Old 07-25-2016, 01:50 AM
What Trust Fund
Pops
Do you know any local shops that can just do a quick check to see if its a belt issue or something else?
Old 07-25-2016, 09:54 AM
Patches
Patches's Avatar
Kohle at American Heritage and Ryne at CMS. Take your pick - either will give you excellent service and outstanding quality.
Old 07-27-2016, 01:17 AM
B y r o n
B y r o n's Avatar
Check your exhaust manifold bolts, make sure they are all there and none have snapped. If the sound is there primarily when cold and goes away when warm could be an exhaust leak. The heat expands the metal and seals the leak so sound goes away or diminishes.
Old 07-28-2016, 09:49 PM
American Heritage
Supporting Vendor
American Heritage's Avatar
Received 1,012 Likes on 533 Posts
Give us a call
310-326-2399
or shoot us an email
HP@americanheritageperformance.com
We will get you squared away.
http://www.americanheritageperformance.com/
To Weird noise from under the hood...
Quick Reply: Weird noise from under the hood...
