Code Test
Received 1,404 Likes
2017 C7 of the Year Finalist
St. Jude Contributor
Code Test
Code:
CODE LIST 10-PCM - Powertrain Control Module P0101 Mass Air Flow (MAF) System Performance P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency P0107 Manifold Pressure (MAP) Sensor Circuit Low Voltage P0108 Manifold Pressure (MAP) Sensor Circuit High Voltage P0112 Intake Air Temp (IAT) Sensor Circuit Low Voltage P0113 Intake Air Temp (IAT) Sensor Circuit High Voltage P0117 Engine Coolant Temp (ECT) Sensor Low Voltage P0118 Engine Coolant Temp (ECT) Sensor High Voltage P0118 Engine Coolant Temperature (ECT) Excessive Time to Closed Loop Fuel Control P0131 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1 P0132 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1 P0133 Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1 P0134 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1 P0135 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1 P0137 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2 P0138 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2 P0140 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2 P0141 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 2 P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1 P0152 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1 P0153 Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1 P0154 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1 P0155 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1 P0157 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2 P0158 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2 P0160 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2 P0161 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2 P0171 Fuel Trim System Lean Bank 1 P0172 Fuel Trim System Rich Bank 1 P0174 Fuel Trim System Lean Bank 2 P0175 Fuel Trim System Rich Bank 2 P0230 Fuel Pump Control Circuit P0300 Engine Misfire Detected P0325 Knock Sensor (KS) System P0327 Knock Sensor (KS) Circuit Front P0332 Knock Sensor (KS) Circuit Rear P0335 CKP Sensor Circuit P0336 CKP Sensor Circuit Performance P0341 CMP Circuit Performance P0342 CMP Sensor Circuit Low Voltage P0343 CMP Sensor Circuit High Voltage P0351 Ignition Control #1 Circuit P0352 Ignition Control #2 Circuit P0353 Ignition Control #3 Circuit P0354 Ignition Control #4 Circuit P0355 Ignition Control #5 Circuit P0356 Ignition Control #6 Circuit P0357 Ignition Control #7 Circuit P0358 Ignition Control #8 Circuit P0410 AIR System P0412 AIR Solenoid Relay Control Circuit P0418 AIR Pump Relay Control Circuit P0420 TWC System Low Efficiency Bank 1 P0430 TWC System Low Efficiency Bank 2 P0441 EVAP System No Flow During Purge P0461 Fuel Level Sensor 1 Circuit Performance P0462 Fuel Level Sensor 1 Circuit Low Voltage P0463 Fuel Level Sensor 1 Circuit High Voltage P0480 FC Relay 1 Control Circuit P0481 FC Relay 2 and 3 Control Circuit P0500 VSS Circuit (M/T) P0506 Idle Speed Low P0507 Idle Speed High P0522 Engine Oil Pressure Sensor Circuit Low Voltage P0523 Engine Oil Pressure Sensor Circuit High Voltage P0530 A/C Refrigerant Pressure Sensor Circuit P0562 System Voltage Low P0563 System Voltage High P0567 Cruise Resume Circuit P0568 Cruise Set Circuit P0571 Cruise Brake Switch Circuit (M/T) P0601 PCM Memory P0602 PCM Not Programmed P0604 PCM RAM Performance P0606 PCM Internal Communication Interrupted P0608 VSS Output Circuit P0650 MIL Control Circuit P0654 Engine Speed Output Circuit P0704 Clutch Switch Circuit (M/T) P0705 Transmission Range Switch Circuit (A/T) P0706 Transmission Range Switch Performance (A/T) P0801 Reverse Inhibit Solenoid Control Circuit (M/T) P0803 1-4 Upshift Solenoid Control Circuit (M/T) P0804 1-4 Upshift Lamp Control Circuit (M/T) P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage P1114 ECT Sensor Circuit Intermittent Low Voltage P1115 ECT Sensor Circuit Intermittent High Voltage P1120 TP Sensor 1 Circuit P1125 APP System P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1 P1134 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1 P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1 P1154 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1 P1220 TP Sensor 2 Circuit P1221 TP Sensors 1, 2 Performance P1258 Engine Coolant Over Temperature-Fuel Disabled P1275 APP Sensor 1 Circuit P1276 APP Sensor 1 Circuit Performance P1280 APP Sensor 2 Circuit P1281 APP Sensor 2 Circuit Performance P1285 APP Sensor 3 Circuit P1286 APP Sensor 3 Circuit Performance P1380 EB (T) CM DTC Detected- Rough Road Data Unusable P1381 Misfire Detected - No EB (T) CM/PCM Serial Data P1415 AIR System Bank 1 P1416 AIR System Bank 2 P1431 Fuel Level Sensor 2 Circuit Performance P1432 Fuel Level Sensor 2 Low Voltage P1433 Fuel Level Sensor 2 High Voltage P1441 Evaporative Emissions (EVAP) System Flow During Non-Purge P1514 TAC System MAF Performance P1515 Command vs Actual Throttle Position Performance (PCM Module) P1516 Command vs Actual Throttle Position Performance (TAC Module) P1517 TAC Module Processor P1518 PCM to TAC Module Serial Data Circuit P1539 A/C Clutch Status Circuit High Voltage P1545 A/C Clutch Relay Control Circuit P1546 A/C Clutch Status Circuit Low Voltage P1571 ASR Desired Torque P1574 Stop Lamp Control Circuit P1575 Extended Travel Brake Switch Circuit High Voltage P1626 Theft Deterrent System Fuel Enable Circuit P1630 Theft Deterrent System PCM In Learn Mode P1631 Theft Deterrent System Password Incorrect P1635 5 Volt Reference #1 Circuit P1639 5 Volt Reference #2 Circuit P1644 Delivered Torque Output Circuit P1652 Powertrain Induced Chassis Pitch Output Circuit 28-TCS - Traction Control System C1214 Sol Valve Relay Contact or Coil CKT Open C1217 BPMV Pump Motor Relay Contact CKT Open C1221 LF Wheel Speed Sensor Input Signal is 0 C1222 RF Wheel Speed Sensor Input Signal is 0 C1223 LR Wheel Speed Sensor Input Signal is 0 C1224 RR Wheel Speed Sensor Input Signal is 0 C1225 RF Excessive Wheel Speed Variation C1226 LF Excessive Wheel Speed Variation C1227 LR Excessive Wheel Speed Variation C1228 RR Excessive Wheel Speed Variation C1232 LF Wheel Speed Circuit Open or Shorted C1233 RF Wheel Speed Circuit Open or Shorted C1234 LR Wheel Speed Circuit Open or Shorted C1235 RR Wheel Speed Circuit Open or Shorted C1236 Low System Supply Voltage C1237 High System Supply Voltage C1241 Magna Steer Circuit Malfunction C1242 BPMV Pump Motor Ground Circuit Open C1243 BPMV Pump Motor Stalled C1255 EBTCM Internal Malfunction CEBCM Internal Malfunction C1261 LF Inlet Valve Solenoid Malfunction C1262 LF Outlet Valve Solenoid Malfunction C1263 RF Inlet Valve Solenoid Malfunction C1264 RF Outlet Valve Solenoid Malfunction C1265 LR Inlet Valve Solenoid Malfunction C1266 LR Outlet Valve Solenoid Malfunction C1267 RR Inlet Valve Solenoid Malfunction C1268 RR Outlet Valve Solenoid Malfunction C1273 RF TCS Master Cyl Isolation Valve Malfunction C1274 RF TCS Prime Valve Malfunction C1276 Delivered Torque Signal CKT Malfunction C1277 Requested Torque Signal CKT Malfunction C1278 TCS Temporarily Inhibited By PCM C1281 Steering Sensor Uncorrelated Malfunction C1286 Steering Sensor Bias Malfunction C1287 Steering Sensor Rate Malfunction C1291 Open Brake Lamp Sw Contacts During Deccel C1293 DTC C1291/C1292 Set Curnt/Prev Ign Cylce C1294 Brake Lamp Switch Circuit Always Active C1295 Brake Lamp Switch Circuit Open U1016 Loss of Communications with PCM U1255 Generic Loss Communications U1300 Class 2 Circuit Shorted to Ground U1301 Class 2 Circuit Shorted to Battery
