test
test
http://forums.corvetteforum.com/c6-z...post1581069510
http://forums.corvetteforum.com/c6-z...post1581069741
http://forums.corvetteforum.com/c6-z...post1581069046
http://forums.corvetteforum.com/c6-p...m-pkg-ls7.html
http://forums.corvetteforum.com/c6-z...post1577227079
The first one I found was Charles Scavone back in November 2005.
Charles Scavone 2006 Model Dropped Valve Street cruising.
whitjo 2006 Model Dropped Valve Street cruising
Raceguy 2006 Model Track spun Bearing
dg144 2006 model Oil Starvation Track Oil starvation
fastbluels6 2006 Model Dropped valve, street.
capitalpiggy 2006 Model Valve.
kennyC6 2006 Model Dropped Valve Street
Larry T 2006 Model Bearing Failure.
TFAST4U 2006 Model Street. Oil pump failure.
upsetatchevy 2006 Model Bearing Failure
euro749 2006 Model Valve, Street
http://forums.corvetteforum.com/c6-c...-replaced.html
Bmore30 2007 Model "Seized" on Street
Pistol Champ 2007 Model Dropped Valve, street
CodeBlack 2007 Model Stock street.
BLKLS7 2007 Model stock Dropped Valve, Street.
tjwong 2007? Describes a failure in a car belonging to a customer of his.
snapsZ06 2008 Model Oil pump failure, street.
Joe_Planet 2008 Model Track, possible valve
elh0102 2008 Model Track Oil Related Failure Bearing?
Pro531cad 2008 model cracked piston, street.
DoctorV 2008 Model Broken valve spring, valve likely contacted pistons, street.
Darius 2008 Valve failure, track
RedSSR 2008 Model "Seized"
blue 85 2008 Model Spun Bearing
rikhek 2008 Valve, Street
Schilitj
EdCalVette
noredlights
Tardis
Rod Knockin'
Philco
taken19
sebaj
BornSupercharged
KB9GKC
james1990 power adder
3544S cam supercharger
cdaniel525 cam
Patrick57 dropped valve LS2
1. CGZ06 2009 stock 34,670 miles
2. Cyclone09Z06 2009 stock 18,200 miles
3. jmurf28 Stock 2006, 13,555 miles[/B]
4. fmcockc 39,000 miles failed on track
5. http://forums.corvetteforum.com/c6-z...valve-6-a.html
6. http://forums.corvetteforum.com/c6-z...-help-pls.html
7. http://forums.corvetteforum.com/c6-c...-vr-39-5k.html
8. http://forums.corvetteforum.com/c6-z...rop-valve.html
9. Bill Dearborn
10. TheKomoman
http://forums.corvetteforum.com/auto...anty-list.html
11. jrgeorge27
List of Claimed Stock LS7 engine failures in cars belonging to members of CF
Charles Scavone 2006 Model 1,000 miles 11/26/05 Dropped **intake Valve Street cruising. Broken **intake Valve Spring. Track History: Unknown
Whitjo 2006 Model 2/23/08 Dropped Valve Street cruising rocker failed, Broken Valve Spring broke, valve dropped Mobil 1 5w30? Track History: None
66L72 2006 Model 1/3/09 Oil Starvation Track, * Mobil1 5w30 Track History: Yes
Ruf-Racer 2006 Model 3/13/08 *Two* LS7 engines replaced under warranty. Low Oil Pressure Both Failures* tracked, tracked, tracked Track History: Yes
Raceguy 2006 Model 2/10/07 Spun Bearing at 2,600 miles Track * Track History: Yes
dg144 2006 Model 8/30/08 Oil Starvation* track Mobil 1 Track History: Yes
Sprite2005 2006 Model 6/30/06 Valve Street failed rocker, Broken Valve Spring Track History: None
Mr-Z 2006 Model 12/13/06 Valve Street Broken Valve Spring Track History: Unknown
Montana Cowboy 2006 Model 15,000 miles 7/19/07 Head Gasket Track History: Unknown
Whosurdaddy 2006 model 3/19/08 Oil Starvation, or valve??? but on track track Mobil 1 5w30* Track History: Yes
capitalpiggy 2006 Model 8/11/09 Dropped Valve Broken Valve Spring Street
kennyC6 2006 Model 6/27/10 Dropped Valve street
Larry T 2006 Model 11/??/2006 Spun Bearing * Track History: Yes
Blemley 2006 Model 8/16/07 Rod Bearing
Wesh60 2006 Model 2/14/06 Unknown cause. Failed at 581 miles..
TFAST4U 2006 Model 11/29/07 Street. Oil pump failure. Track History: None
upsetatchevy 2006 Model 7/22/10 Bearing Failure
euro749 2006 Model 3/28/07 Valve Street
CodeBlack 2006 Model 8,000 miles 10/02/07 Stock street. * Track History: Yes
Jeff Leaver 2006 Model 6/??/11 Dropped Valve Broken Valve Spring track * Track History: Yes
Slim Shady valve
The "breakdown":
21 reports of failed stock motors in 2006 models.
9 valve related, 6 of them said to have been "broken valve springs"
4 bearings
5 oil starvation or low oil pressure
3 unknown
1 Head Gasket
Bmore30 2007 Model 21,000 miles 03/31/08 "Seized" on Street
Pistol Champ 2007 Model 16,000 miles 06/18/09 Dropped Valve, street. Mobil1 5w30 in 3 times for bad rockers they changed them all 6 weeks later dropped valve
bvanwoud 2007 Model 31,000 miles 01/17/10 Valve Street
camirocz 2007 Model 35,000 miles 8/30/10 street unknown, but got a rebuild after dealer "didn't like what they saw in the oil they dumped" during a routine oil change.*
Cor Dame 2007 Model 08/12/08 Valve Spring Two engines One Lifter, One broken valve spring Street * Track History: Yes
KRAYZ308 2007 Model 09/10/10 Dropped Valve * Track History: Yes
Hoefi 2007 Model 09/??/09 Dropped Valve Track * Track History: Yes
UR2SLO 2007 Model 11/30/09 Dropped Valve broken valve springStreet
BLKLS7 2007 Model 11/05/09 stock Valve. broken valve spring Street
50thragtop 2007 Model 2/13/08 Valve broken valve spring Street
TrooperDLA 03/29/12 bearing failure possibly due to faulty oil pump Street
The "breakdown":
12 reports of failed stock motors in 2007 models.
8 valve related. 4 of them said to have been "broken valve springs"
1 "seized"
1 bearing failure
1 Lifter
1 unknown
ctdeng0 2008 Model 9/25/11 *Two* LS7 engines to fail under warranty. 1st failure rod bearing 2nd failure "rod bearing" * Track History: Yes
snapsZ06 2008 Model 06/08/10 Oil pump bypass valve failure, street.
Joe_Planet 2008 Model 05/09/09 Oil Starvation Track * Track History: Yes
07C6Z 2008 Model 10/28/11 Dropped Valve
elh0102 2008 Model 05/28/08 Track Oil Related Failure Bearing? * Track History: Yes
Pro531cad 2008 model 10/21/07 cracked piston, street.
Darius 2008 06/25/11 Valve failure, track * Track History:
DirtyHowie 2008 Model 87,000 miles 10/26/11 Dropped Valve * Track History: Yes 87,000 miles and approximately 30 track days
Tailwag 2008 Model 09/15/09 Piston
blue 85 2008 Model 6,054 miles 11/10/08 Spun Bearing
MarkusWelby 2008 Model Second of two LS7 engine failures. First LS7 failed was tuned. Then replacement LS7 engine failed after approx. 3500 miles question as to if all debris had been removed from oil tank and lines from first failure. * Track History: Yes
Marcosis 2008 Model 3,000 miles 05/28/08 Oil Starvation Track yes Yes
Hulksdaddy 2008 Model 11/27/07 Bearing Failure. Rod bolt improperly torqued
rikhek 2008 33,000 miles 07/02/11 Valve, Street * Track History: Yes 8 track days, 1,432 track miles
TheKomoman 2008 Model 06/03/12 Dropped Valve???? Mobil 1 track* Track History: Yes 5-6 track days per year, car purchased 1/2009, motor popped 6/3/2012
The "breakdown":
16 reports of stock failures in 2008 models.
5?? valve related.
5 bearings
3 oil or oil pump related
2 pistons
1 Oil Starvation
Mrimpala02 2009 Model 10,3xx miles 08/13/09 Failed Oil Pump
Alchemist31 2009 Model 6,700 miles 11/03/11 broken Valve Spring Street
The "breakdown":
2 reports of failed stock motors in 2009 models
1 Valve related. That 1 said to have been "broken valve spring"
1 Crank bearing failure
MOSPORT1 2011 Carbon Model 5,890 miles 7/5/12 Spun Rod Bearings Track History: No
The "breakdown":
1 reports of failed stock motors in 2011 models.
1 Rod bearings.
* indicates car has seen some track duty. Dates are typically when first reported. However there are instances where the actual incident preceded the report by several days, weeks, or even months. In those instances, an attempt was made, by reviewing the report and owner's prior additional posts, to accurately list the actual date of the incident wherever possible.
Reserve the space 99
A
American power valve train
apicia valve
B
Balducci70 piston and sleeve cam only
bowtiguy
C
connyv valve cam only
D
David_Yu piston LPE Cam Only package
dfinke23 piston Cam and heads SS valves
dvandentop valve cam only QM600
E
EGash exhaust valve Cam cnly
EXCELR8 exhaust exhaust valve, cam only
F
FASTBLUEZ06 Spun bearings, SS valves, lash caps on wrong valves, metal into engine, spun bearings.
flyinmedic cam power adder spun bearings
FNQWK lethal cam, forged internals, bearing failure
G
H
htvette cam only, head gasket?
I
IrishC6 Cam taken back to stock, spun bearing
K
kelp valve cam only
L
LS7 Bud cam only exhaust valve
M
mr.algaz blower cam only, blower, windowed block
N
NOSZ06 Cam QM 600, Nitrous, dual springs 33k miles on them, intake valve spring broke, bent intake valve
O
P
PrestonG (forged internals)
Q
R
RichieRichZ06 cam only valve or possibly piston failure
Rusc6z06 cam only piston ring cracked sleeve
S
Scuba_Steve cam and heads, stock valves, broken exhaust valve
spartanc6z06 cam only valve??
steve stubbs cam only, bearings?
s2pdfst_z06 cam only exhaust valve head came off
T
TJ Wong report of customer's car from another shop failing on his dyno, valve or piston, extensive carnage
U
Unreal Cam PRC 285 heads blower, cam gear came off
V
VREDZ06 Cam and Heads, Exhaust valve dropped, heads were using the original valves
W
Whatcop? Cam only dropped exhaust valve
X
Y
Yfzkevin
Z
ZESHAWN
Z0sicktanner
Z06 Norway
1
1badassZ 2007 valve
1000yardman
12BVETTEOWNER suspected valve
2
2008 Corvette
Reserved
A
Angry Z
B
Bonds youtube
C
Chris Daniel
Cole Trickle
D
E
F
Fast06Z06
J
jad568
O
orangecrrrush
T
Torchvette10
V
VIPRETR
W
wannagofast ok
Reserved
A
Andi
B
Bikerpuke
Bill Dearborn
BlackmagicZ
BlaznZ06
BLKZ
C
CamaroAJ
Captain454
Chad06Z06
Cobraq8
Corvee
Corvee
D
Dicaprio
dpracing
Drivermod44
E
EVO1313
F
flpaul
Frenchican
Funkybird
G
Gary2KC5
H
HVDT
HVDT
I
J
JohnnywoZ
JYC5 ok
K
kawiilaosboy
kentz06
KLLRVET
L
Lankhoss
LPFSTheFett
Lucxy
M
Matteo
MILT IV
Minkster
Mjolitor
MP3pic
N
O
P
Project Opel
Proteam
Q
R
ratt_finkel
Red SSR
S
Samuk
SleeplessinSeattle
Slim Shady Valve
Songman
Stano
T
Tailwag
TJ Wong report
U
V
W
Whirls
Whosurdaddy valve
X
Y
Z
Zmark06
Z0sicktanner
Z06Menace valve
ZoomZ
1
#1Hand 2008 Valve
http://www.z06vette.com/forums/f64/d...ge-fix-120501/
http://www.z06vette.com/forums/f71/h...i-blew-115606/
According to Judy Jin (Design Release Engineer for the LS7 cylinder head) the intake has 4 and the exhaust has 3.
"After the seats are installed, they are machined to the proper angles. On the all-important intake, starting at the combustion chamber roof, the seat angles are: 39°, 45°, 60° and 71.83° followed by a radius. The exhaust seats are cut with 38.17°, 45° and 76° angles, then a radius. In both cases, the valve face seats on the 45° portion. Each seat and radius are machined by one milling tool in a single plunge movement of the 5-axis CNC's table."
She also states that two different valve seats are used. The intake seat is made of a specific material, PMF 28, which is compatible with the titanium intake valve. The exhaust valve seat, also supplied by F-M, is Brico 3220 material, used in a variety of GM aluminum heads.
http://www.camarohomepage.com/ls7/
Like the thread title says, some of us thought it a good idea to get a feel for how many on this forum have changed from the OEM hollow stemmed exhaust valves, over to a solid stainless exhaust valve.
Here's what it looks like so far:
Count is 417 C6 Z06 owning CorvetteForum members who have previously switched to, currently have builds or builds in progress which will be running, or have experience in their LS7s with running, "heavier" than stock exhaust valves and "upsetting" stock valve train dynamics and "slaughtering" their redlines. Be they doing it with Inconel or Ferrea Super Alloy, Ferrea's new partly drilled exhaust valve, or Solid stemmed stainless steel, in stock or aftermarket castings.
*******This thread as it is set up, is intended to be informative. So to that end the names are hyperlinked to prior posts describing key elements of the owner's build, to include, but not limited to, the cylinder heads in the car, and components used within them, ancillary modifications, and in most cases, which professionals were involved in the builds.
The listing is broken down alphabetically, numerically, and geographically.
The listing is a "Global" listing, in that it includes cars from parts of the world outside of the United States. The CorvetteForum, is the largest Corvette Centric forum of it's type.
This fact should give the reader an indication as to the extent the use of this technique goes in the management of the LS7 stock valve drop issue.
Owners and those interested in this topic, may study the listings and the wide range of information contained within the hyperlinks and using it, make what they deem to be the appropriate professional inquiries with regard to this matter.
This method might save the viewer the trouble of wading through the BS and distractions, which typically come from those who agree with GM's selection of the stock, thin walled, hollow stemmed factory LS7 valves, despite several cases in here documenting their failure. Indeed, had you not heard of the failures of the stock LS7 valves, well you probably would not be in here.
At any rate, the following listing is set up for your perusal. Use it to your advantage. As you study it and absorb the information, speak with professionals who have familiarity and actual practical experience with this technique, the use of non sodium filled SS exhaust valves in the LS7.
Good luck, and enjoy your perusal of the listing which we who have taken the steps to avoid a windowed engine block due to a failed stock LS7 valve, fondly refer to as "The Registry".
Ricky J ('06 Quicksilver Z06)
A
Achilles97
adamgl
Aeons 2008 +
andy82
Aedwardsix
airindia33 2007
Alberta_Z06
andreas g.
Andy K
ANGRY Z
anth115 2006
AreOhBeeC6Z
avenger88
azZ06Mike
14 (1)
B
badassf4i
Badddz06
BadZ Ferrea Super Alloy
BAD_TCR+
BayAreaSS
barneygookle382
baro0k@eXtermination + Mast
Beach Bum+
Ben01C5
big_mike_eu 2008 +
blackc6z
blackbelt 2006 +
Blacktavert 2008 +
BLKBRD69+
Blue by u
BLWN427
BgBoost1
Bonnets02Vette 2006 +
Boscosz28
BoostdM3
Boosted Josh+
bowtiguy
Brian@RPT
briancb1
Briansshop
BSheppard
busaetr
Buddy A
Burnin4
bryandwightharris@gm
bx goat
31 (9)
C
C5FRCpewter 2006 +
c5racr1
C6 Curtis
CamzillaZ
Canuck
Captain Z
carbonite77
cdngolfer
chetly+ 2007
CHIWS6
chadyellowz06
Chris2000
CHOPPER1
Cidz06 2006 +
circuswings
CobraAaron
cobrasmith
Cvette713
C5Lion
C54CSTER
C6Zhopeful393
C_Williams@RPM E Force Build
Chevybob
Chonger 2007 +
ClarksZ06
Clogan
Corvee
colts95ta 2007 +
Cozmo
ctsv510 2006 +
Cvette713
31 (7)
D
dannboss
darkbluez
dascorcher21
DaytonaFIC6
dcamick 2006 +
Deadfast
DelaWhere 2008 +
Despicable Z+ inconel
dfinke23
dkal70 2006 +
donatez06
double06 2006 + Ferrea Competition Plus SS Exhaust Valves F2042P
D-Rod
Drazga
Dre01SS
DSKREET 2006 +
Dsteck
Dirty Howie
drfeelgood
duff1857
Dugmole
duhveed+
DUMAN 2008
dvandentop
24 (7)
E
Ecs vette82 2008
edmundu
EnginerdVT 2008 + Mast
erichg1000
eroc022
Evil427 2 builds Ferrea Ferrea Superalloy in the first, and currently Ferrea Competition Plus SS Exhaust Valves F2042P +
Evilness
EvilZ51
Evolution-ary 2007 +
extents
EX1
11 (3)
F
Falcon Tech
Famous RR
Fartpipe
FASTBLUEZ06
Fifedogg
FNQWK
fperra Ferrea Super Alloy
felo357
fly a Z06
fowl69 2006
FrankTank
FRChilln
FRDnemesis
FreakC6Z06
FSTFRC
FreeBoost
Funkybird
FU 2006
f8f2Bearcat
19
G
Gannet
ghoust
Godfather
Gigapunk
GIO-305
GMuffley
go_mer
greatone61+
GregK
Griffee
10 (1)
H
hapnermw
harrydirty+
harveyjl Inconel
HCICC6Z
Header
Hercules Rockefeller
ht600 Ferrea Superalloys
hoefi
HornZ
htvette
HyperX
11 (1)
I
IanM
ibleedgreen
icrashevos
iNeedSpeed
InflatableDog
ioutrun
ipmtim
IrishC6
8
J
J.Abbot
Jawnathin
jbvaldez
JChastain
jconnors316 2008 + Ferrea Competition Plus SS Exhaust Valves F2042P
JCox23+ 2008
JDIllon Katech Street Attack
j hebert
jedblanks
jeffreystar
Jeremy@RPMTransmissions
jimbob8915
jnv255
JJFormato
jkrlucas Katech Street Attack LS7 with Ferrea Super Alloy exhaust valves and bronze valve guides as of 1/13.
jmerola
jmorgan07z06 2007 +
JMNZ06 2007 +
jnel04 2006 +
jnv255+
JoesC5+
johncbourg
jophis37
JsnMR52 Mast
Justinlamanna Mast
jtjohn1 Ferrea Competition Plus SS Exhaust Valves F2042P 2009 +
JwT
JWY Z06
28 (8)
K
kamafnkazi 2007 +
Keith N
KentZ06Ferrea Super Alloy
kenw 2009 + Ferrea Competition Plus SS Exhaust Valves F2042P
KillerFRC
KLLRVET
Kotik 2008 + Ferrea Competition Plus SS Exhaust Valves F2042P
7 (3)
L
LanceFitzgiben
lane_change
Lawdogg
lawman34203+
lebvette 2008 +
Leroy 07 z06 2007 +
Les-10 2008 +
Let It Rein
lilredvette05
LMBTom
LMB-Z 2006 +
LOUFY
LowETz
LS7 Bud
LS7 Drew
LT1Pat 2006 +
LT5 John
lucki86
LUV2SPD
Lynch Z06 2009 +
20 (7)
M
Macattack
Madsen
MAG STAR
Mangum+
MarkC
mariofromnewyork
Matt Clawson Ferrea
Matt-P 2009 +
mazeroth
mdaniel
Meanjoe Ferrea Superalloy
meatheadgn
Mike06Z06
Mike.D
Mookster Ferrea Superalloy.
msd127
Mudcrutch
MudZ06
Myhardtop
MySelfAffliction
20 (2)
N
NachosZ06
Nate B 2006
NavyAirTraffic Ferrea Competition Plus SS Exhaust Valves F2042P 2007 +
NC_427_Vert*
NDAGRUV 2008+
nd3
Nick 02 Z06
NJKGR8YT
NO CHNCE
No4Play
NO SHOW 2006 +
NWbluez06 Ferrea Super Alloys, 25K miles.
NY06Z06 Manley HD
EX1
nyerby
15(3)
O
OJCrush08
oldcrow471
Omega Man 2006 +
ONESLOWZ0 video
onthjug 2008
OrangeSix
6 (1)
P
parsonsj Inconel
patch68 2006 +
Peter Clark 2006 +
PeteZ06
phatbeatnut
philpacs
phipp85 2011 + Ferrea Competition Plus valves
phxcobra
pomppe
prr1 video
Property1!
pwnall1331 2008 +
12 (4)
Q
qnitro 2006
1 (1)
R
Racie
Racin Z06
racetoy
ralphsmithiii
RamAir972003
rattt g
RedZ4me
RGT
richy rich Ferrea + 2006
rio95 2007+
Roadtrip120+
RichieRichZ06
ripptide56
Rick@RKT56
Rock36
Rupertpupkin 2007 +
RWE 427
RyneZ06
rzmnco
19 (4)
S
Samatbama 2008 +
savaGe
sanstackie665
scemo start
1SLEEPYZ
SlowestZ
Scuba_Steve
scottss Ferrea
screaminchevy
See06
seung012
setxws6
Sicc
siksvt03cobra
silvrhand + 2008
Sixbills
skywalker
SlowVet05+
Sm5654
SmokinZ
softy91 Ferrea
soldier4life
SONKIST 2008 +
spicytuna
spdmn75
sriser 2009 +
SS MPSTR
ssracer337
SSMOKE
Stage Runner
stangeater01
stanger383
stano
starchedup
starr1 Ferrea Competition Plus SS Exhaust Valves F2042P 2008 +
stepa j
stew1100+
Stroker_9 2006 +
svre46
svtgeoff
SVTLOL
szaro1 2007
42(8)
T
tail_lights+
taylor757
The Devil Z
TheDingo+
Tfavor2007
The_Ruski_Driver 2008 +
TJ@RPMtransmissions
tjwong Ferrea Super Alloy
torqjunky
ToppThat
track junkie
trackpilot
Track Z06 Manley Severe Duty
Treadhead+
triblk6spd
Troy6166 Ferrea Competition Plus SS Exhaust Valves F2042P 2007 +
TRSCobra 2006 +
Trudat 2nd car with SS valves.
Trudat One with over 30K miles on it.
TT32VGT
tt350z
Turbo2L 2008 +
Turbo Kid
Turbosixx
turbotank 2006 +
25 (8)
U
UBNZO6D
Uncledibble
Undy
Unreal
4
V
VetteFish
veilseven 2007 +
venomous-v
VETTETHREAT 2007 +
VictoryRedZ06
5 (2)
W
walhan_qtr
wesellit
WhiteDiamond
WhiteKnight 2008+
whtturbot@aol.com
Witt748
wjrive 2010 +
Woz Z06
8 (2)
X
XDemonX
Xplosive Performance
2
Y
yankee15 2007 + Ferrea
yellowzron
yfzkevin
youzzi714+
yuniel
5 (2)
Z
ZedNought6 2008 +
Z O SICK
zoomz
Zoxxo
z06king
Z06 Steve 2006 +
z06tx
Z06_505
z0sleeper
zman62
ZR-1 Mark 2006 +
zuli
Z2Z
13(3)
1SLOLT1+
02magred
02sscamaro
'06 Quicksilver Z06
07_r1
06-Z0SICK Ferrea Super Alloy
08VRZ06
1Sikstik
1stZ
12 oh 2006
2000FRCZ19
2013 Z06 2013 +
1badassz
1z062nv
10gt5 + 2008
427ZM
50 4Ever
619grappler
66L72
69dodgecharger
69 Vette Mast
240sx2jz
2V4NOW
66biskwik
95jersey
1981turbota
26 (3)
Members running bronze valve guides and stock or titanium exhaust valves:
Confused garage
Musicmankeb
FNBADAZ06
H82BFST
lgsdds
80atez
Morris
NOSZ06
Werks
torqjunky
DaOtherOne
Now lets get an idea of which states, territories, and countries are represented.
So if your state shows up in your profile, signature or avatar, then you are listed under your respective state, territory, or country as well.
Alabama
BSheppard
EvilZ51
stew1100
Samatbama
Alaska
American Samoa
Arizona
AzZ06Mike
Evilness
jophis37
NachosZ06
phxcobra
SlowVet05
Arkansas
lilredvette05
08VRZ06
lebvette
California
andreas g.
Dirty Howie
C5Lion
C_Williams@RPM
C54CSTER
MAG STAR
FamousRR
Zuli
fly a Z06
InflatableDog
Jawnathin
DUMAN
Keith N
LS7 Drew
Nick 02 Z06
JMNZ06
RGT
RichieRichZ06
SS MPSTR
Stage Runner
UBNZ06D
VetteFish
ZOXXO
50 4Ever
softy91
619grappler
RyneZ06
69dodgecharger
VictoryRedZ06
savaGe
youzzi714
Treadhead
Chetley
Evolution-ary
qnitro
Colorado
bowtiguy
walhan_qtr
Scuba_Steve
erichg1000
Connecticut
Delaware
DelaWhere
District of Columbia
Florida
BadddZ06
chadyellowz06
Gannet
GIO-305
Sixxbills
C6 Curtis
Parsonsj
LT5 John
BLKBRD69
ralphsmithiii
trackpilot
zoomz
Georgia
ANGRY Z
racetoy
SLEEPYZ
badassf4i
ibleedgreen
mazeroth
jnv255
drfeelgood
Falcon Tech
phipp85
Guam
Hawaii
Idaho
Illinois
HyperX
Witt748
yellowzron
ToppThat
PeteZ06
Woz Z06
FrankTank
CHIWS6
Turbo Kid
z0sleeper
Blacktavert
big_mike_eu
Indiana
TJ@RPMtransmissions
C6Zhopeful393
Macattack
DaytonaFIC6
Iowa
KLLRVET
Kansas
Kentucky
Header
Louisiana
blackc6z
J Hebert
ssracer337
troy6166
Turbosixx
Maine
Maryland
rzmnco
Rick@RKT56
double06
Massachusetts
edmundu
Michigan
OrangeSix
rio95
Minnesota
Lawdogg
ramairws6
HornZ
Mississippi
Scottss
JwT
Missouri
adamgl
barneygookle382
BgBoost1
DSteck
track junkie
dascorcher21
Montana
Nebraska
Sicc
Nevada
New Hampshire
02magred
New Jersey
avenger88
FASTBLUEZ06
IanM
jmerola
ratt g
LUV2SPD
New Mexico
LanceFitzgiben
New York
66biskwik
The Devil Z
NY06Z06
bx goat
Aeons
Z06 Steve
North Carolina
felo357
Mark Clawson
NC_427_Vert
1SLOLT1
VETTETHREAT
HCICC6Z
C5FRCpewter
North Dakota
Northern Marianas Islands
Ohio
MudZ06
GMuffley
NO CHNCE
Mudcrutch
starr1
Oklahoma
Boscosz28
Leroy 07 z06
Oregon
tjwong
Madsen
Pennsylvania
Fartpipe
wesellit
2013 Z06
dcamick
Puerto Rico
Rhode Island
South Carolina
FRDnemesis
South Dakota
Chevybob
dvandentop
veilseven
Tennessee
Blue by u
Texas
BADZ
BAD_TCR
Beach Bum
Brian@RPT
Buddy A
EViL427
kamafnkazi
screaminchevy
Cvette713
Corvee
Cozmo
No4Play
EX1
FST FRC
htvette
Meanjoe
jedblanks
jeffreystar
IrishC6
Sm5654
lane_change
LMBTom
Mike06Z06
myhardtop
NJKGR8YT
Racie
ripptide56
RWE 427
setxws6
spdmn75
torqjunky
triblk6spd
Omega Man
z06tx
1badassZ
WhiteDiamond
stepa j
KillerFRC
Roadtrip120
silverhand
LMB-Z
jmorgan07z06
Cidz06
jnel04
Utah
Unreal
z06king
meatheadgn
Vermont
Virginia
Undy
OJCrush08
MarkC
kenw
sriser
Virgin Islands
Washington
fperra
kentZ06
NWbluez06
Mookster
TRSCobra
West Virginia
D-Rod
Wisconsin
Wyoming
Canada
Canuck British Columbia.
msd127 saskatoon Saskatchewan, Canada
06-Z0SICK North Bay Ontario
Z06 BUD Hamilton Ontario
66L72 Keswick Ontario
cdngolfer King City Ontario
nupsi Edmonton Alberta
FreeBoost Calgary Alberta
Albrerta_Z06 Calgary Alberta
spicytuna Canmore, Alberta
1z062nv Toronto Ontario
Europe
jbvaldez Baumholder Germany
Rock 36 Stuttgart Baden-Württemberg Germany
nd3 Graf Germany
1981turbota Bavaria Germany
pomppe Orivesi Finland
Peter Clark Devon England
Kotik Germany
Middle East
Cars which have suffered engine failures since around June 2012.
I added this section to the listing for further informational purposes and I will be updating it from time to time along with the rest of the listing.
1. CGZ06 2009 stock 34,670 miles Dropped valve
2. Cyclone09Z06 2009 stock 18,200 miles Dropped valve
3. Jackal 2006 56,000 miles cam only Dropped valve
4. jmurf28 Stock 2006, 13,555 miles[/B]
5. fmcockc 39,000 miles failed on track Dropped valve
6. Gary Glasser 2006 Z06, dropped a valve at 40k miles
7. jad568 2007 45,000 miles failed while being backed out of parking lot
8. AreOhBeeC6Z 29,000 miles, bolt ons
9. Daniel Hoffele 2007 49K miles CAI, Catback, stock tune.
10. philpacs 2006, 30K miles
11. turbo50mike 2007 no prior mention of the incident that I can find before the hyperlinked thread. Dropped Valve. Replaced engine under warranty
12.*DaWizard Dropped Valve
13.*kawaiilaosboy Dropped Valve
14. z0silk 2007 55,000 miles engine replaced under warranty after dropped valve.
15. Vividz06 '07 30K miles 2 hrs on a track 20k later.
16. boost2na '09 17,300 miles.
17. dsharkman '07 17,775 miles. Billy Boat Exhaust and a Halltech Killer Bee intake.
18. jph331 '07 86,000 miles. Lost a valve into the #1 cylinder. Unknown if it was an exhaust or intake valve.
19. Stanger383 '07 20,000 miles.
20. The Black Bitch 2008 30,000 miles dropped exhaust valve.
21. punchz06 2009 Dropped stock exhaust valve, 27,000 miles. Headers, custom grind cam, new springs, vararam intake.
22. Madsen 2006 10K on a cammed motor, dropped a SS valve running OEM stock powdered metal valve guides which were completely shot. This after having dropped a stock exhaust valve several months prior.
23. Corvee Bent a SS valve which went on to break.
24. qtr_c6z06 2008 20K miles, unknown failure. Windowed block
25. zamora7 2007 36K miles. Windowed block.
26. BEZ06 2006 47,000 miles CAI, Tune. Very large hole in block.
27. kattigrr 2009 40,000 miles bone stock. Broken exhaust valve pics.
28. jbednarsh 2007.
29. cantevendrive75 dropped valve.
30. Slacker1201 2012 10,201 miles, #5 & #6 rod bearings.
31. CWW17 2007 52,000 miles.
32. rstandke 2009 Dropped Stock Exhaust Valve, 23,800.
33. AmitZ06 2006 52,000 miles
34. Radbrooks 2009 41K miles, oil starvation.
35. theseal 2008 bone stock, dropped exhaust valve, at 61,000 miles.
36. o6zo6vette 07 38,574 miles failed piston.
37. quicked 2007 less than 9,000 miles on car. Cam only setup. Broken stock exhaust valve 300 miles later.
38. NotVincent 2013 427 Vert. 5,000 miles. "connecting rods did not have enough clearance and ground bits of titanium into my oil"
39. LittleBlueBMW 2009 Dropped Valve at 26K miles. Stock except for upgraded brakes and tires. Failure occurred on track.
40. Dallas 123 2008 cam, headers, dropped 2 valves while cruising at 2200 RPM.
41. j zammy 2008 40K miles dropped valve during normal driving.
42. Donny07Z06 2007 42K miles dropped valve.
43. richie427 2007 35,000 miles dropped valve Pic
44. panos dropped exhaust valve. 35,000 miles 2008
45. bstedman 2006 51,000 miles dropped stock valve.
*Described SS valve failures, aftermarket cylinder head mishaps, and misadventures.
* Missed the start of the thread cut, but only by days.
ECS videos. Other videos.
10..8/9
7/6
3/7
0/0
25
http://forums.corvetteforum.com/1587391675-post14.html
http://forums.corvetteforum.com/1587351313-post23.html
http://forums.corvetteforum.com/c6-c...h-c-i-z06.html
http://forums.corvetteforum.com/c6-c...fs-07-zo6.html
http://forums.corvetteforum.com/c6-c...-900-rwhp.html
A
Achilles97
adamgl
Aeons 2008 +
andy82
Aedwardsix
airindia33 2007
Alberta_Z06
andreas g.
Andy K
ANGRY Z
anth115 2006
AreOhBeeC6Z
avenger88
azZ06Mike
14 (1)
B
badassf4i
Badddz06
BAD_TCR+
BayAreaSS
barneygookle382
Beach Bum+
Ben01C5
big_mike_eu 2008 +
blackc6z
blackbelt 2006 +
Blacktavert 2008 +
BLKBRD69+
Blue by u
BLWN427
BgBoost1
Boscosz28
BoostdM3
Boosted Josh+
bowtiguy
Brian@RPT
briancb1
Briansshop
BSheppard
busaetr
Buddy A
Burnin4
bx goat
31 (9)
C
C5FRCpewter 2006 +
c5racr1
C6 Curtis
CamzillaZ
Canuck
Captain Z
carbonite77
cdngolfer
chetly+ 2007
CHIWS6
chadyellowz06
Chris2000
CHOPPER1
Cidz06 2006 +
circuswings
CobraAaron
cobrasmith
Cvette713
C5Lion
C54CSTER
C6Zhopeful393
Chevybob
Chonger 2007 +
ClarksZ06
Clogan
Corvee
colts95ta 2007 +
Cozmo
ctsv510 2006 +
Cvette713
31 (7)
D
dannboss
darkbluez
dascorcher21
DaytonaFIC6
dcamick 2006 +
Deadfast
DelaWhere 2008 +
dfinke23
dkal70 2006 +
donatez06
D-Rod
Drazga
Dre01SS
DSKREET 2006 +
Dsteck
Dirty Howie
drfeelgood
duff1857
Dugmole
duhveed+
DUMAN 2008
dvandentop
24 (7)
E
Ecs vette82 2008
edmundu
erichg1000
eroc022
Evilness
EvilZ51
extents
EX1
11 (3)
F
Falcon Tech
Famous RR
Fartpipe
FASTBLUEZ06
Fifedogg
FNQWK
felo357
fly a Z06
fowl69 2006
FrankTank
FRChilln
FRDnemesis
FreakC6Z06
FSTFRC
FreeBoost
Funkybird
FU 2006
f8f2Bearcat
19
G
Gannet
ghoust
Godfather
Gigapunk
GIO-305
GMuffley
go_mer
greatone61+
GregK
Griffee
10 (1)
H
hapnermw
harrydirty+
harveyjl Inconel
HCICC6Z
Header
hoefi
HornZ
htvette
HyperX
11 (1)
I
IanM
ibleedgreen
icrashevos
iNeedSpeed
InflatableDog
ioutrun
ipmtim
IrishC6
8
J
J.Abbot
Jawnathin
jbvaldez
JChastain
JCox23+ 2008
j hebert
jedblanks
jeffreystar
jimbob8915
jnv255
JJFormato
jmerola
jmorgan07z06 2007 +
JMNZ06 2007 +
jnel04 2006 +
jnv255+
JoesC5+
johncbourg
jophis37
JsnMR52 Mast
Justinlamanna Mast
JwT
JWY Z06
28 (8)
K
kamafnkazi 2007 +
Keith N
KillerFRC
KLLRVET
7 (3)
L
LanceFitzgiben
lane_change
Lawdogg
lawman34203+
lebvette 2008 +
Leroy 07 z06 2007 +
Les-10 2008 +
Let It Rein
lilredvette05
LMBTom
LMB-Z 2006 +
LOUFY
LowETz
LS7 Bud
LS7 Drew
LT1Pat 2006 +
LT5 John
lucki86
LUV2SPD
Lynch Z06 2009 +
20 (7)
M
Macattack
Madsen
MAG STAR
Mangum+
MarkC
mariofromnewyork
Matt Clawson Ferrea
Matt-P 2009 +
mazeroth
mdaniel
meatheadgn
Mike06Z06
Mike.D
msd127
Mudcrutch
MudZ06
Myhardtop
MySelfAffliction
20 (2)
N
NachosZ06
Nate B 2006
NC_427_Vert*
NDAGRUV 2008+
nd3
Nick 02 Z06
NJKGR8YT
NO CHNCE
No4Play
NO SHOW 2006 +
NY06Z06 Manley HD
EX1
nyerby
15(3)
O
OJCrush08
oldcrow471
Omega Man 2006 +
ONESLOWZ0 video
onthjug 2008
OrangeSix
6 (1)
P
parsonsj Inconel
patch68 2006 +
Peter Clark 2006 +
PeteZ06
phatbeatnut
philpacs
phxcobra
pomppe
prr1 video
Property1!
pwnall1331 2008 +
12 (4)
Q
qnitro 2006
1 (1)
R
Racie
Racin Z06
racetoy
ralphsmithiii
RamAir972003
rattt g
RedZ4me
RGT
rio95 2007+
Roadtrip120+
RichieRichZ06
ripptide56
Rick@RKT56
Rock36
Rupertpupkin 2007 +
RWE 427
RyneZ06
rzmnco
19 (4)
S
Samatbama 2008 +
savaGe
sanstackie665
scemo start
1SLEEPYZ
SlowestZ
Scuba_Steve
scottss Ferrea
screaminchevy
See06
seung012
setxws6
Sicc
siksvt03cobra
silvrhand + 2008
Sixbills
skywalker
SlowVet05+
Sm5654
SmokinZ
softy91 Ferrea
soldier4life
SONKIST 2008 +
spicytuna
spdmn75
sriser 2009 +
SS MPSTR
ssracer337
SSMOKE
Stage Runner
stangeater01
stanger383
stano
starchedup
stepa j
stew1100+
Stroker_9 2006 +
svre46
svtgeoff
SVTLOL
szaro1 2007
42(8)
T
tail_lights+
taylor757
The Devil Z
TheDingo+
Tfavor2007
TJ@RPMtransmissions
torqjunky
ToppThat
track junkie
trackpilot
Treadhead+
triblk6spd
TRSCobra 2006 +
TT32VGT
tt350z
Turbo2L 2008 +
Turbo Kid
Turbosixx
turbotank 2006 +
25 (8)
U
UBNZO6D
Uncledibble
Undy
Unreal
4
V
VetteFish
veilseven 2007 +
venomous-v
VETTETHREAT 2007 +
VictoryRedZ06
5 (2)
W
walhan_qtr
wesellit
WhiteDiamond
WhiteKnight 2008+
whtturbot@aol.com
Witt748
wjrive 2010 +
Woz Z06
8 (2)
X
XDemonX
2
Y
yellowzron
yfzkevin
youzzi714+
yuniel
5 (2)
Z
ZedNought6 2008 +
Z O SICK
zoomz
Zoxxo
z06king
Z06 Steve 2006 +
z06tx
Z06_505
z0sleeper
zman62
ZR-1 Mark 2006 +
zuli
Z2Z
13(3)
1SLOLT1+
02magred
02sscamaro
'06 Quicksilver Z06
07_r1
08VRZ06
1Sikstik
1stZ
12 oh 2006
2000FRCZ19
2013 Z06 2013 +
1badassz
1z062nv
10gt5 + 2008
427ZM
50 4Ever
619grappler
66L72
69dodgecharger
69 Vette Mast
240sx2jz
2V4NOW
66biskwik
95jersey
1981turbota
26 (3)
Confused garage
Musicmankeb
FNBADAZ06
H82BFST
lgsdds
80atez
Morris
NOSZ06
Werks
torqjunky
DaOtherOne
Alabama
BSheppard
EvilZ51
stew1100
Samatbama
Alaska
American Samoa
Arizona
AzZ06Mike
Evilness
jophis37
NachosZ06
phxcobra
SlowVet05
Arkansas
lilredvette05
08VRZ06
lebvette
California
andreas g.
Dirty Howie
C5Lion
C_Williams@RPM
C54CSTER
MAG STAR
FamousRR
Zuli
fly a Z06
InflatableDog
Jawnathin
DUMAN
Keith N
LS7 Drew
Nick 02 Z06
JMNZ06
RGT
RichieRichZ06
SS MPSTR
Stage Runner
UBNZ06D
VetteFish
ZOXXO
50 4Ever
softy91
619grappler
RyneZ06
69dodgecharger
VictoryRedZ06
savaGe
youzzi714
Treadhead
Chetley
Evolution-ary
qnitro
Colorado
bowtiguy
walhan_qtr
Scuba_Steve
erichg1000
Connecticut
Delaware
DelaWhere
Florida
BadddZ06
chadyellowz06
Gannet
GIO-305
Sixxbills
C6 Curtis
Parsonsj
LT5 John
BLKBRD69
ralphsmithiii
trackpilot
zoomz
Georgia
ANGRY Z
racetoy
SLEEPYZ
badassf4i
ibleedgreen
mazeroth
jnv255
drfeelgood
Falcon Tech
phipp85
Guam
Hawaii
Idaho
Illinois
HyperX
Witt748
yellowzron
ToppThat
PeteZ06
Woz Z06
FrankTank
CHIWS6
Turbo Kid
z0sleeper
Blacktavert
big_mike_eu
Indiana
TJ@RPMtransmissions
C6Zhopeful393
Macattack
DaytonaFIC6
Iowa
KLLRVET
Kansas
Kentucky
Header
Louisiana
blackc6z
J Hebert
ssracer337
troy6166
Turbosixx
Maine
Maryland
rzmnco
Rick@RKT56
double06
Massachusetts
edmundu
Michigan
OrangeSix
rio95
Minnesota
Lawdogg
ramairws6
HornZ
Mississippi
Scottss
JwT
Missouri
adamgl
barneygookle382
BgBoost1
DSteck
track junkie
dascorcher21
Montana
Nebraska
Sicc
Nevada
New Hampshire
02magred
New Jersey
avenger88
FASTBLUEZ06
IanM
jmerola
ratt g
LUV2SPD
New Mexico
LanceFitzgiben
New York
66biskwik
The Devil Z
NY06Z06
bx goat
Aeons
Z06 Steve
North Carolina
felo357
Mark Clawson
NC_427_Vert
1SLOLT1
VETTETHREAT
HCICC6Z
C5FRCpewter
North Dakota
Ohio
MudZ06
GMuffley
NO CHNCE
Mudcrutch
starr1
Oklahoma
Boscosz28
Leroy 07 z06
Oregon
tjwong
Madsen
Pennsylvania
Fartpipe
wesellit
2013 Z06
dcamick
Puerto Rico
Rhode Island
South Carolina
FRDnemesis
South Dakota
Chevybob
dvandentop
veilseven
Tennessee
Blue by u
Texas
BADZ
BAD_TCR
Beach Bum
Brian@RPT
Buddy A
EViL427
kamafnkazi
screaminchevy
Cvette713
Corvee
Cozmo
No4Play
EX1
FST FRC
htvette
Meanjoe
jedblanks
jeffreystar
IrishC6
Sm5654
lane_change
LMBTom
Mike06Z06
myhardtop
NJKGR8YT
Racie
ripptide56
RWE 427
setxws6
spdmn75
torqjunky
triblk6spd
Omega Man
z06tx
1badassZ
WhiteDiamond
stepa j
KillerFRC
Roadtrip120
silverhand
LMB-Z
jmorgan07z06
Cidz06
jnel04
Utah
Unreal
z06king
meatheadgn
Vermont
Virginia
Undy
OJCrush08
MarkC
kenw
sriser
Virgin Islands
Washington
fperra
kentZ06
NWbluez06
Mookster
TRSCobra
West Virginia
D-Rod
Wisconsin
Wyoming
Canada
Europe
nd3 Graf Germany
Kotik Germany
Middle East
28. jbednarsh 2007.
10..8/9
7/6
3/7
0/0
25
set motor in a vice
hook up a good grond wire
hook up a power wire to the pos side of where the wires attach
then using a test lightyou can check rest of poles to see what is getting pthen using the power wire you can touch it to different poles to see what speeds are working.
8. AreOhBeeC6Z 29,000 miles, bolt ons Dropped Valve
10. philpacs 2006, 30K miles Dropped Valve
15. Vividz06 '07 30K miles 2 hrs on a track 20k later. Dropped Valve
16. boost2na '09 17,300 miles. Dropped Valve
17. dsharkman '07 17,775 miles. Billy Boat Exhaust and a Halltech Killer Bee intake. Dropped Valve
