at
at
The Z06 utilizes the FE4 suspension, not available on other Corvette models. FE4 uses a larger front stabilizer bar, stiffer rear leaf spring, and revised camber settings "calibrated for maximum control during high-speed operation".
2001/2 Front Alignment Specifications
All Models
Front Individual Toe
+ 0.04
+/- 0.10
Front Sum Toe
+ 0.08
+/- 0.20
Steering Wheel Angle
0.0
+/- 1.0
FE1 & FE3
Front Individual Caster
+ 7.4
+/- 0.5
Front Cross Caster
Within +/- 0.5
Front Individual Camber
- 0.20
+/- 0.5
Front Cross Camber
Within +/-0.5
FE4 (Z06)
+ 6.9
+/- 0.5
Front Cross Caster
Within +/- 0.5
- 0.70
+/- 0.5
Front Cross Camber
Within +/- 0.5
Rear Alignment Specifications
All Models
Rear Individual Toe
- 0.01
+/- 0.10
Rear Sum Toe
- 0.02
+/- 0.20
Rear Thrust Angle
0.0
+/- 0.10
FE1 & FE3
Rear Individual Camber
- 0.18
+/- 0.5
Rear Cross Camber
Within +/- 0.5
FE4 (Z06)
- 0.68
+/- 0.5
Rear Cross Camber
Within +/- 0.5
Greater negative camber helps increase the tire contact patch in aggressive cornering situations.
Ref.
Ref.
C'ya
D
Corvette5D
View Public Profile
Find More Posts by Corvette5D
05-10-2005, 02:47 PM
All Models
+ 0.04
+/- 0.10
Front Sum Toe
+ 0.08
+/- 0.20
0.0
+/- 1.0
FE1 & FE3
+ 7.4
+/- 0.5
Front Cross Caster
Within +/- 0.5
- 0.20
+/- 0.5
Front Cross Camber
Within +/-0.5
FE4 (Z06)
+ 6.9
+/- 0.5
Front Cross Caster
Within +/- 0.5
- 0.70
+/- 0.5
Front Cross Camber
Within +/- 0.5
All Models
Rear Individual Toe
- 0.01
+/- 0.10
Rear Sum Toe
- 0.02
+/- 0.20
Rear Thrust Angle
0.0
+/- 0.10
FE1 & FE3
- 0.18
+/- 0.5
Rear Cross Camber
Within +/- 0.5
FE4 (Z06)
- 0.68
+/- 0.5
Rear Cross Camber
Within +/- 0.5
Ref.
Ref.
C'ya
D
Corvette5D
View Public Profile
