28' Enclosed Haulmark Edge trailer FS (NC)...
This trailer was $14,600 new retail. It’s the middle model as I didn’t need the observation platform that the Ultimate Edge had, nor did I want a plywood interior that the base model had. It has approx 10K+ miles on it. All 4 hubs have been completely repacked and all 4 of the brake pickups replaced. It has 4 brand new Load Range E tires. This trailer is READY to haul. It needs nothing. I will deliver to VIR if payment in full is made prior to delivery.
This trailer is in GREAT condition. It has been taken well taken care of. I don’t need to sell it, but I don’t really need it any more, at least for right now. I’ll probably regret selling it. My loss, your gain.
$8500 OBO, don’t bother to low ball me or ask for more pictures unless you are serious.
I have the title in hand. Remember, I said "OBO".
PM me or email thru my signature info.
28’ Haulmark “Edge” Trailer – Victory Red
Model: EG85X28WT3
Width: 8 ½’ – 100” Wide Body
Width Between Wheel Wells: 82”
Safety Chains: 12,600lb Gold Safety Chains w/Gold Hook
4 Brand New Maxxis Load Range “E” tires - Less than 200 miles on tires
Aluminum Fender Flares
Axle Width: Wide Track
Hub Type: EZ-Lube Hubs
Suspension: Tandem 5200lb Axles with Torflex (Rubber Ride Suspension)
GVWR: 10000lbs
Brakes: Electric Brakes on both axles
Wheel Accessories: Chrome Wheel Caps, Chrome Lug Nets with 4 Wheel Locks, 2 Key Socket Locks
Wheels: 6 Bolt Pattern with ½” studs
Wheels: Aluminum with 12 Holes
Cap: Stainless Cap – Not the Base model plastic cap that will crack and leak
Finish: .030 Aluminum Exterior
Floor Covering: ¾” Plywood Flooring with complete ATP Floor covering
Insulation: Insulated Ceiling
Main Rails: 2” x 8” Tube Main
Rust Inhibiting Chassis Protection
Crossmember Spacing: 16” on center
Crossmembers: Z crossmember
Chrome Rear Header
Nose & Corners” Stainless Steel Front Nose Cap, Cast Aluminum Corners
Roof: 1 Piece Aluminum Roof
Roof Bow Spacing: 16” on center
Roof Bows: Hat Section Roof Bows
Sidewall Construction: Dust Resistant Sidewalls
Sidewall Liner: 3/8” Plywood Sidewall Liner with .030” Aluminum wall liner
Stoneguard: 24” ATP Stoneguard
Vertical Post Spacing: 16” on center
Vertical Posts” 86 ¾” Hat Posts
Interior Height: 79” – Your head won’t be hitting the fluorescent lights
Side Door: 48” Door with Recessed-lock
A-Frame Coupler: 2 5/16” 10,000lb coupler with Break-away switch
Beavertail: 96” Beavertail with spring and Cam-Locks
Lighting: 12V Deluxe Dome Light
Fluorescent Lighting: 110V 4’ fixtures with Diffuser
30A Circuit Breaker Panel
Shore Power: 30 Amp exterior plug near generator door
Air Conditioning: Carrier AirV 13,500 Nominal BTU Cooling Capacity w/Heater strip
L-shaped Aluminum Work Bench/Overhead Cabinets with Generator Door
Generator Door: 36’ x 33”
Added by myself since purchasing new:
Storage shelf: 4’ x 8’ x ½” Plywood rack on E-Track that can be easily removed if needed.
Tire Rack – Holds Five or Six 315 width tires – Folds up if needed
Exterior Dual 110V Outlet near Side Door and one near Beavertail
2 Sets of 5Klb D-Ring Tie-down rings – 8 total D-rings
Wall Mounted E-track to tie-down rolling Tool Chest under Tire Rack
Fuel Storage: 1 rectangle box that holds two 5 gallon square fuel jugs
Brand new spare tire/wheel: Goodyear Marathon ST225/75R15 BSL 2540# 65PSI on factory 12 hole Aluminum wheel
4’ extended ramps with rubber/nut retainer
Available if you want to purchase:
TV/DVD to play a couple of GGW DVD's I'll throw in, not for the faint of heart - $50
Shore Power cables – Two 50’ Marinco Marine 30A cables on Storage reel - $80
Drive Up Ramp to change tire - $10
Horse Step - $25
T-ring tie-down attachments - $15
Craftsman 5 drawer tool-chest - $100
Four 3-ton Car-stands - $30
Craftsman 4 ton floor jack - $100
Microwave - $50
Model: EG85X28WT3
GVWR: 10000lbs
Chrome Rear Header
Horse Step - $25
Microwave - $50
