FS test 4 99
FS test 4 99
1999 Corvette convertible. Prize winning show car for sale in Orange County, California.
COME SEE THIS CAR AT THE "CRUISIN' FOR A CURE" CAR SHOW AT THE ORANGE COUNTY FAIRGROUNDS ON SATURDAY, SEPTEMBER 27, IN THE "FOR SALE BY OWNER" BUILDING!
http://www.cruisinforacure.com/
Built September 30, 1998. Took delivery October 28, 1998. Original owner.
MILEAGE 36,531 (9/23)
Automatic transmission.
Only factory options are Active Handling System and fog lamps.
The car spent the first years of its life as a weekend cruiser until July 2005, when it was in a minor rear-end accident at a stop light. I had the car repaired at one of the premier body shops in Orange County (European Motor Car Works), where they also replaced the front and rear facias (Tecstar Tiger Shark), hood (Motor City Mold), and installed (non-functional) Breathless Performance rear brake ducts. Over the next few years, cosmetic mods to the engine compartment and interior, as well as many other appearance mods, transformed a stock C5 Corvette into a show car winning dozens of awards in shows in Southern California.
This car has only been used for gentle weekend cruising, car shows, and the occasional road trip. Never wrung out, never raced, always garage kept, waxed and covered. Any chips in the paint were filled promptly.
WHY I'M SELLING IT
It's been my dream car, but I've owned it for 16 years, and I'd like to move on to something new.
Asking $27,000. PRICE IS NOT FIRM! PRICE IS NEGOTIABLE!
PM or burner22@***.net
INTERIOR
Steering wheel: Full hydrocarbon rim w/grips & flat-bottom, modified by Down South Vettes.
Hydrocarbon console lid, modified by Apsis.
Seats: Corbeau A4, black leather, excellent condition. No power function.
Carbon fiber style shift boot and handbrake boot.
AUDIO SYSTEM
Bezel for double-din head unit, wrapped in hydrocarbon, modified by Double D Mods.
Head unit: Pioneer AVH-P4100DVD w/30-pin Ipod connector cable.
Speakers: Pioneer in front, Polk in rear. No subwoofer.
Amplifier: Pioneer GM-6400F (600-watt, 4-channel), mounted in trunk compartment.
All audio components (except for rear speakers) professionally installed.
A/C SYSTEM
Standard manual-control system. Recharged June 2014. A/C blows ice cold.
EXTERIOR
Front & rear genuine Tecstar/Starcraft Tiger Shark facias.
Genuine Motor City Mold carbon fiber hood with clear center panel.
Breathless Performance rear brake ducts (cosmetic only, non-functional).
Lambo doors, installed by Vertical Doors Inc. (original hinges for conversion back to stock included).
ENGINE COMPARTMENT
Engine is a 100% stock LS1. All underhood mods are cosmetic except for air intake.
Intake: K&N w/carbon fiber top, and high flow carbon fiber power duct. A 2nd K&N filter & duct (w/ California CARB sticker) is included.
Carbon fiber & hydrocarbon covers: Wheel well covers, battery compartment cover, fuel rail covers, radiator top cover, radiator reservoir cover, windshield cowl and wiper arms.
Real chrome (not SS) covers: Intake cover, alternator cover, power steering reservoir cover, throttle body cover, brake fluid reservoir cover (all from Creative Engine Covers) and filler caps.
EXHAUST
Corsa Indy Pace Car w/Tiger Shark tips. X-pipe installed.
TIRES, WHEELS AND BRAKES
Michelin Pilot Sport PS2 tires (non run-flat). 275/30ZR19 front, 305/30ZR19 rear. 6/32" tread depth all around.
4 19" CCW 505A polished aluminum wheels. Excellent condition, no road rash.
Slotted & drilled brake rotors. Red powdercoated brake calipers. Stainless steel brake caliper plates.
Full set of 20 Gorilla wheel locks w/key
MAINTENANCE RECORDS
Nearly complete set of maintenance records available.
MAINTENANCE ISSUES
Brakes work fine, except for a little bit of pulsing when braking at slow speeds. Rotors possibly need turning.
Trunk release button on key fob doesn't work. Dashboard trunk release button works fine.
Occasionally, after about 45 min/1 hour, the ventilation system stops blowing air, although the fan keeps running. Usually, shutting the car off and restarting clears the problem.
MISCELLANEOUS
Suspension lowered on stock bolts.
Column lock bypass installed.
Originally equipped with a LoJack system. However, I've never had it serviced or inspected.
Checked regularly for OBD codes. Hasn't thrown a code in the 5 years I've been checking.
Need more info or pictures? Please contact me.
THANK YOU FOR LOOKING AT MY CAR! HOPE YOU LIKE IT!
