1990 zr1 code43
1990 zr1 code43
replace knock sensor
replace esc module. send ecm for testing and repair if needed
was told no problem with ecm re install ecm code 43 comes back on
all test for wiring ok. line485 voltage at 10volts reading to knock sensor normaly. need help thank you
nobody home?????
Wrong forum. This forum is for testing of something related to posting and the forum.
Go here and post about your problem:
https://www.corvetteforum.com/forums...discussion-50/
After 10 years - Learning to Multi Quote
replace esc module. Send ecm for testing and repair if needed
wrong forum. This forum is for testing of something related to posting and the forum.
