Rms-man
Rms-man
Bad dealings with this guy. I was overseas and just got back...opened used fan assembly from this guy and one of the supporting arm's are missing...like...cut off completely! How could he of not mentioned this before!!!!!! and, why would I buy it if I knew it was like this!
Joshua Dodson is his real name.
Take a deep breath. I did not scam you.
The fan has been trimmed near the top where a s/c inlet would fit right there. That in no way hurts the performance of the fan. That fan also does not have the fan module which I noted in the for sale thread, hence the cheaper price.
The picture in my thread is of that actual fan you got as well.
http://forums.corvetteforum.com/c6-p...dules-etc.html
All 4 of the arms that actually attach the fan to the radiator all are still intact. You will have no problems using that fan. We used it on the '07 Vette that I pulled it off of without any problems. I'm the last person that is going to try and scam anyone.
Joshua Dodson
C6 Cooling Fan Assembly (minus control module & factory connector)
Description: Removed from ’07 Vette worked great, swapped for SPAL dual fans.
Mileage: 28,000
Price: $100 plus shipping
Mileage: 28,000
Joshua Dodson
You never mentioned once that you had modified it. I would of not bought it if I knew you hacked on it.
bad seller. Now I have to go buy a new one. Thanks dbag.
PM sent. I will take that one back and give you refund or send you the other complete fan that has the module and all still attached. I'm not into scamming people, I will make this right if you let me.
don't need the name calling guy offered to take it back....
did you contact him BEFORE you posted this thread per forum rules?
