Are ccw classics 17x9.5/18x12 lighter than stock z06 wheels?
I think identically sized they are very similar in weight (i.e. w/in a half pound). I wouldn't say the classics are considered a "drag wheel"; they do make a size package specifically suited for drag racing, but a lot of people use (other sizes of CCWs) for road racing, so their application is very broad depending on size, etc.
Originally Posted by C6this
Oh ok cool. I wonder how much more a 18x12 would weigh in the back compared to 18x10.5?
DH
Wheel size,type, & Weight in lbs ea
OEM MAG 17 x 8.5, 17.5
OEM MAG 18 x 9.5, 19.5
OEM MAG 18 x 9.5 w/ new Yoko 295/35-18 AVS sport non-runflats, 50
OEM MAG 18 x 9.5 w/ new Yoko 275/35-18 AVS sport non-runflats, 46
PWO 17 x 8.5 +58mm, 20
PWO 18 x 9.5 +65mm, 23
PWO 17 x 8.5 +58mm w/ oem runflat 245/45/17 (8/32 tread), 50
PWO 17 X 8.5 +58mm w/ new MT ET Street 26 x 11.50 x 17 with TPS & lots of weights, 45
OEM MAG 17 x 8.5 w/ NITTO 555 275/40/17 (1/2 tread), 45
OEM MAG 18 x 9.5 w/ stock OEM 275/40/18 runflats, 53
OEM MAG 17 x 8.5 w/ stock OEM 245/45/17 runflats, 47
OEM MAG 17 x 8.5 w/ new MT ET Street Radial 275/40/17, 47
CCW drag pack rear 16 x 10 classic full polished with well worn MT ET Street 26 x 11.50 x 16 (1/32” tread) with center caps, 34
CCW drag pack front 16 x 5 classic full polished with like new Firestone deluxe champion 5.00/5.25-16 (10/32” tread) with center caps, 33
OEM runflat 275/40/18 worn to wear bars, 29
Bridegstone expedia S-01 345/35/18, 37
New MT ET Street Radial 275/40/17 (6/32 tread), 30
New MT ET Street 26 x 11.50 x 17 tires (6/32 tread), 25
OEM runflat 245/45/17 (8/32 tread), 29
BFG G-force drag radial 345/30/18, 30
Topline 18 x 10.5 +58mm offset rims w/ 275/35/18 BFG G-force TA drag radial, 53
HRE 18 x 9.5 545 w/ clear center +58mm, 22
HRE 18 x 12 545 w/ clear center +74mm, 27
HRE 18" x 12 545 w/ 345/30/18 BFG DRS, 57
HRE 18 x 9.5 545 w/ clear center +58mm w/ new 275/35/18 BFG KDWs, 52
HRE 18" x 12 545 w/ 345/35/18 EXPEDIA S-O1 9/32 tread, 64
HRE 19" X 10" 545 w/ Yoko 295/35-19 AVS sport non-runflats (5/32 tread), 58
Wow - just the question I was going to ask! Do you or anyone else have the weight for Z06 Motorsports compared to stock C5? I believe they're heavier, just interested in how much. Apparently it's just enough to throw off the F55 computer so I get random (and harmless) error messages. Thanx.
DH
Originally Posted by Dirty Howie
I had the Motorsports and could feel the exta weight from stock. But I never had any F55 problem. I have since removed the F55 and gone to Z06 springs and Bilstein shocks.
DH
DH
I don't think I'd get the F55 again (at least not unless its performance is refined and upgraded) but I'm not sure I feel strongly enough about it to opt for major surgery, so to speak.
Removed the F55? I presume that means that you left all the electronics in place and just changed shocks? If so, how do you shut off the system so it doesn't keep yelling through the DIC that it's been bypassed?
I did it cause I was lowering the car and didn't want to ruin the F55 shocks. They also cost a fortune to replace if they ever go bad. So I got rid of the whole system.....always had it set in sport mode anyways.
DH
Well, in retrospect, I leave it set in Sport all the time now anyway, partly because of the need to damp the (slight) extra weight of the Z06 Motorsports (I should add - in Z06 size = extra inch of width front and back, therefore a heavier tire as well). Except when my wife is riding with me, she insists on the Tour despite the fact I think the ride is floaty on that setting. Oh well, live and learn, but I'd certainly go for the Z51 next time around.
