TSW's on a C6, who has them? Tire sizes?
Myself and quite a few others are wondering about the TSW wheel fitment on the C6 and what the widest rear tire you can run is without hitting the fender lip because of this wheels offset. No one ive talked to cares about rubbing the inner fender liners, just the fenders themselves.
So if you own a set of TSW wheels on a C6, speak up. What size tires are you running? They claim a 305 will clear under all circumstances but i have seen no photo or first hand proof of this.
Thanks!
Thanks!
The 305s fit just fine on the 19 x 10.5 wheels. Here's my setup:
TSW Interlagos, 18 x 9 front, 19 x 10.5 rear
Bridgestone Potenza RE-11 tires, 265/35-18 front, 305/30-19 rear
My car ('05 Z51 Pkg) is lowered as much as the factory suspension allows. No rubbing whatsoever, even at full steering lock, and that's driving it aggressively at an autocross in a lot with some significant bumps.
I'm really pleased with this setup, and the tire sizes keep the front/rear diameter ratio correct, so there's no issues with stability control, ABS, etc.
DASH2005 (02-02-2018)
I was running 275/35 fronts on a 10" wheel and 325 rears on a 11" wheel before and had NO issues with rubbing either but I wanted to make sure that these offsets would not cause a problem. Can you see any problems with the rear tire making contact under full suspension compression?
Thanks for taking the time to comment here....
Looking straight down the rear fender, the tire is pretty much flush with the fender lip, but with the camber gained with roll, the tire tucks in a little. I bought a set of GM splash guards to protect the paint from stone chips (again, installed after the pics were taken). They're great for that factory-finished look.
