Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Rally Wheel Codes.
Old 04-25-2002, 01:41 AM
DaBo
DaBo's Avatar
Default Rally Wheel Codes.
Years ago, Super Chevy, Hot Rod or????? listed the explanation of the codes on Chevy rally wheels. Anyone have this info.
Thanks in advance.
Old 04-27-2002, 08:42 PM
67HEAVEN
67HEAVEN's Avatar
Default Re: Rally Wheel Codes. (DaBo)
CHEVROLET RALLY WHEEL DATA
Old 04-27-2002, 09:08 PM
DaBo
DaBo's Avatar
Default Re: Rally Wheel Codes. (67HEAVEN)
That's what I was looking for.......
Thanks,
David
Old 05-28-2014, 07:32 PM
Grrvett
1st Gear
Grrvett's Avatar
Default Rally wheel codes
K- kelsey
1 - plant 1 romulus MI
2- year 1972
There are more numbers somewhere on the wheels
XA 14X5 BS-3 1/2 67 Chevy II with drum brakes
DA 14X5 BS-3 7/8 67 Chevy II RALLY with disc brakes
DG 14X6 67 Camaro & Chevelle with discs brakes
XB 14X6BS -4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle
XN 14X6 BS-3 3/4 68-69 Camaro & Nova with drum brakes. Different shaped outer
AE 14X6 BS-4 3/8 70 Chevelle Station Wagon
XG 14X6 BS-3 7/8 68-69 Camaro with discs brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal
DE 14X6 BS-4 3/8 71-72 Nova & Chevelle, 6 hole wheels
YW 14X6 BS-4 3/8 Exactly like XB, may have come on same cars
YJ 14X7 BS-4 3/8 69 Camaro/ Chevy II L72- ZL1, 70 Nova
AV 14X7 70-72 Camaro, 71-72 Nova, 6 hole wheel
XT 14X7 L72- ZL1 Non Rally Wheel
YA 14X7 BS-4 3/8 69 Chevelle SS Wheel
AO 14X7 BS-4 3/8 70 Camaro &69 Chevelle SS Wheel
DB 15X5 67 Passenger Cars with disc brakes.
DF 15X6 BS-4 1/16 67-68 Camaro Z28
DC (BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim
DC 15X6 BS-3 1/2 68-70 Passenger car, 67 Passenger car (early models)
FI 15X6 BS-3 1/2 68-70 Passenger car, 67 Passenger car (later models) Riveted instead of welded together
YS 15X6 BS-3 1/2 68-70 El Camino
FW 15X7 BS-4 1/4 71-up most any GM
AG 15X7 BS-3 3/4 68 Corvette (will take 15x8 Beauty rings)
YH 15X7 BS-4 1/4 L72- ZL1 Z28 Rally 69 narrow drop center
AD 15X7 BS-4 1/4 L72- ZL1 Z28 Rally 68 wide drop center
AV 15X7 70, 71, 73 CAMARO Z28 5 spoke wheel
AZ 15X8 BS-4 69-82 Corvette
Here are a few extra notes:
*BS-Backspacing
* All the rally wheels made in 1967 have big marking letters, no date code, a little bit different shaped center and slightly bigger holes in the center.
* The 15x7 beauty ring will go on all the 15x6 wheels.
*Also 6 = 6th month/June
26= Day of the month
Old 06-16-2014, 09:03 PM
pop23235
pop23235's Avatar
Received 1,022 Likes on 682 Posts
I have a set of DC or DG. Stamping is light in the critical area. Any idea what else to look for to make a distinction? How "big" is a "big DC"?
To Rally Wheel Codes.
Quick Reply: Rally Wheel Codes.
