NEW Ruff 954 Concave wheels for C5 and C6 aplications
#52
Ruff 954
Hi guys
I am interested in finding out from those of you who run the Ruff 954's how well they balance. If you force balance do they run smoothly at high speeds? I am looking for a vibration free ride similar to the factory wheels.
What tires are you running for extreme summer performance on a base C6?
Can you replace the Ruff center cap with one bearing the C6 logo?
#54
St. Jude Donor '08
Just to be clear, I have a 2008 C6 (narrow body - Z51) and I have installed the 2008 Z06 - 6 piston front calipers and 4 piston rear calipers on my 2008 C6.
I am interested in possibly purchasing a set of your Ruff Wheels - if they will in fact fit - meaning that the Ruff Wheels will clear the Z06 calipers.
With that said, could you please answer the following:
1. Will the Ruff Wheels fit my described C6 - Z06 Brake set-up without any clearance issues?
2. If spacers are in fact required in order for the Ruff Wheels to clear the Z06 brake calipers on the base C6 platform, can you please tell me exactly what size front and rear wheel hub spacer that would be required in order to provide proper clearance of the Z06 brake calipers while not allowing the Ruff Wheel to protrude beyond the lip of the front and rear wheel wells?
Thanks in advance for your anticipated reply -
#55
Former Vendor
#59
Former Vendor
