Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Z06 tires & wheels on base C5
Old 11-23-2012, 04:07 PM
dstoffel
1st Gear
dstoffel's Avatar
Default Z06 tires & wheels on base C5
What issues will I run into if I put C5 Z06 tires and wheels on a 99 coupe?
I already have the wheels, Need to purchase tires. Road driving only.
Dave
Old 12-14-2012, 05:24 PM
0Luke@tirerack
Former Vendor
Luke@tirerack's Avatar
St. Jude Donor '11-'12
no issues at all ... C5 Z wheels and tires fit a standard C5 with no modifications ...
Old 12-26-2012, 01:37 PM
donald4972
Support Corvetteforum!
donald4972's Avatar
St. Jude Donor '14-'15
i'd love to see and hear how that goes for you, when you're done. pics before and after. I'm thinking of doing the same thing, next time i need new tires. what size tires are you going with?
Don
Old 01-14-2013, 02:12 PM
QCVette
QCVette's Avatar
Don
No problems at all. I did it on my '99.
I went with 255/45/17 front and 285/40/18 rear. This is a close match to keep the speedometer close. (60.7 mph actual shows 60 mph on the speedometer). The stock Z06 sizes (265/40/17 and 295/35/18) are smaller diameter. (58.8 mph actual shows 60 mph on the speedometer) The 255 and 285 sizes work with either the base or Z06 size wheels and the front to back diameter stagger is good to keep active handling/traction control systems happy.
Good luck with your choices.
To Z06 tires & wheels on base C5
Quick Reply: Z06 tires & wheels on base C5
