corect tire pressure for C5 Non-Run Flats
I just put Hankook Evo's on my 2003 C5. the shop put 28 PSI which I thought was low. I put 35 which according to the TPMS warmed up to 39PSI on yesterdays cruise, which I think is high.
I have been unable to find anything on Tire Rack or the Forum which provide the specs for Non-runflats. I want to stop guessing.
thank you
thank you
If you're still running stock size tires, just go with the manufacturer's recommended tire pressure, it's on a big sticker inside the driver's door..... Run flats or non run flats makes no difference.
Former Vendor
and correct
